DVDFab 11.0.9.5
https://www.dvdfab.cn/download.htm
DVDFab 11.0.9.5 Changelog New: Added the support to upscale videos with Enlarger AI on PCs installed with the 10th generation Intel i9 CPUs. New: Added the support to automatically switch to CPU to convert again in case the conversion with hardware acceleration fails. Fix: A problem that the movie name in the Video Converter module is not updated after applying the metadata to the loaded source using the Search Movie/TV feature. Fix: A conversion failure problem in the Video Converter module in certain cases. |
AnyDVD 8.4.9.1 Beta
http://sandbox.redfox.bz/SetupAnyDVD8491.exe
8.4.9.1 2020 06 24 - New (Blu-ray): Support for new discs - Fix (Blu-ray): Missing files when "ripping to folder" |
DVDFab 11.0.9.4
DVDFab 11.0.9.4 Changelog New: Added the support for some new Java protections. Fix: A problem that the auto update does not work. |
DVDFab 11.0.9.3 + Passkey 9.3.9.0
DVDFab 11.0.9.3
https://www.dvdfab.cn/download.htm DVDFab 11.0.9.3 Changelog New: Added the support for some new Java protections. New: Improved the profile preset feature. Fix: A problem that only one copy is made despite the copy quantity is set to 10. Fix: A conversion failure problem in the Ripper modules if the output path contains some special characters. Fix: A problem that the estimated output size is wrong if Audio Copy is selected in the Ripper modules. Passkey 9.3.9.0 http://www.dvdfab.cn/mlink/download.php?g=PASSKEY Passkey 9.3.9.0 Changelog New: Added the support for some new Java protections. |
DVDFab 11.0.9.2
DVDFab 11.0.9.2 Changelog Fix: A crash problem when converting DVD/Blu-ray discs to MP4/MKV videos in certain cases. |
DVDFab 11.0.9.0 + Passkey 9.3.8.8
DVDFab 11.0.9.0
https://www.dvdfab.cn/download.htm DVDFab 11.0.9.0 Changelog New: Added the support for some new Java protections. New: Improved the Preset Profile feature in the Ripper modules. New: Improved the default output video bitrate. Fix: A problem that ***8220;temp***8221; appears in the output file titles if Remux SRT is selected when outputting MKV videos. Passkey 9.3.8.8 http://www.dvdfab.cn/mlink/download.php?g=PASSKEY New: Added the support for some new Java protections. |
AnyDVD 8.4.9.0 + Passkey 9.3.8.7
AnyDVD 8.4.9.0
https://www.redfox.bz/download/SetupAnyDVD.exe 8.4.9.0 2020 06 02 - New: PowerDVD 20 is now supported by AnyDVD's unique Cinavia fix - New: Added PowerDVD 20 info to logfile - New (Installer): Updated Italian translation - New (Blu-ray): Support for new discs - New (DVD): Support for new discs - New (UHD): Added "BLU-RAY-UHD" to disc type in registry - Fix: Pressing ALT key in settings caused controls to vanish - Some minor fixes and improvements Passkey 9.3.8.7 http://www.dvdfab.cn/mlink/download.php?g=PASSKEY New: Added the support for some new Java protections. |
DVDFab 11.0.8.9 + Passkey 9.3.8.5
DVDFab 11.0.8.9
https://www.dvdfab.cn/download.htm New: Added the support for some new Java protections. New: Added the support to downgrade firmwares for BH14NS58 (1.02), BH16NS58 (1.02) and BH16NS40 (1.04) with the UHD Drive Tool. New: Improved the profile preset feature to recommend MP4 profile for home theaters. New: Added the hardware acceleration support on PCs installed with 10th gen Intel GPUs. Fix: A slow conversion problem when upscaling videos with Enlarger AI after switching to another GPU. Fix: A conversion failure problem when outputting DTS audios in Ripper modules. Passkey 9.3.8.5 http://www.dvdfab.cn/mlink/download.php?g=PASSKEY New: Added the support for some new Java protections. |
DVDFab 11.0.8.8
DVDFab 11.0.8.7 + Passkey 9.3.8.4
DVDFab 11.0.8.7
https://www.dvdfab.cn/download.htm New: Added the support for some new Java protections. New: Added the support for the new copy protection as found on certain Japanese adult DVDs. New: Added the support to preset conversion profiles for different scenarios (mobile devices and home theaters) when converting DVDs, Blu-rays and 4K Ultra HD Blu-rays with the Ripper modules.(scroll down for more info) New: Improved the support for the burning engine. Fix: An error 600 problem when copying Blu-rays in certain cases. Fix: A problem that chapters are created when converting certain MKV files with Enlarger AI even there are no chapters in the original files. Fix: A failure problem when converting videos with the MP4.Passthrough profile in the Video Converter module. Passkey 9.3.8.4 http://www.dvdfab.cn/mlink/download.php?g=PASSKEY New: Added the support for some new Java protections. |
DVDFab 11.0.8.6 + Passkey 9.3.8.2
DVDFab 11.0.8.6
https://www.dvdfab.cn/download.htm New: Added the support for some new Java protections. New: Improved the support for Enlarger AI upscaling conversion. Passkey 9.3.8.2 http://www.dvdfab.cn/mlink/download.php?g=PASSKEY New: Added the support for some new Java protections. New: An authorization failure problem if the account password is too long. |
DVDFab 11.0.8.5
New: Added the support for some new Java protections. New: Added the Ultra Quality conversion model when upscaling DVDs in DVD Ripper and 480p videos in Video Converter, with Enlarger AI. More info here: https://forum.dvdfab.cn/forum/softwa...ate#post380934 New: Improved the overall user experience on Installation, Task Manager and Enlarger AI. |
AnyDVD 8.4.8.2 Beta + Passkey 9.3.8.1
AnyDVD 8.4.8.2 Beta
http://sandbox.redfox.bz/SetupAnyDVD8482.exe 8.4.8.2 2020 04 21 - New: PowerDVD 20 is now supported by AnyDVD's unique Cinavia fix - New: Added PowerDVD 20 info to logfile - New (Installer): Updated Italian translation - New (Blu-ray): Support for new discs - New (DVD): Support for new discs - New (UHD): Added "BLU-RAY-UHD" to disc type in registry - Some minor fixes and improvements Passkey 9.3.8.1 http://www.dvdfab.cn/mlink/download.php?g=PASSKEY New: Added the support for some new Java protections. |
AnyDVD 8.4.8.1 Beta
8.4.8.1 2020 04 16
- New: PowerDVD 20 is now supported by AnyDVD's unique Cinavia fix - New: Added PowerDVD 20 info to logfile - New (Installer): Updated Italian translation - New (Blu-ray): Support for new discs |
DVDFab 11.0.8.4
New: Added the support for some new Java protections. New: Improved the speed when opening Blu-rays and 4K Ultra HD Blu-rays. New: Integrated Intel OpenVINO AI technology when upscaling videos with Enlarger AI on PCs installed with 6th-10th Gen Intel Core Series (Also the iGPUs), such as i7-6700, i7-7700, i9-9900, etc. |
| Wszystkie czasy w strefie CET. Aktualna godzina: 12:51. |
