AnyDVD 8.2.9.1 Beta
8.2.9.1 2018 10 07
- New (Blu-ray): Support for new discs - New (DVD): Support for new discs - Some minor fixes and improvements http://sandbox.redfox.bz/SetupAnyDVD8291.exe |
DVDFab 10.2.1.6 + Passkey 9.3.2.0
DVDFab 10.2.1.6
New: Added the support for some new Java protections. New: Added a new menu template in the DVD Creator module. Fix: A crash problem when opening DVD discs in certain cases. http://www.dvdfab.cn/download.htm Passkey 9.3.2.0 New: Added the support for some new Java protections. Fix: A problem that the Lite version cannot start up in certain cases. http://www.dvdfab.cn/mlink/download.php?g=PASSKEY |
AnyDVD 8.2.9.0
8.2.9.0 2018 09 26
- New (Blu-ray): Support for new discs - New (DVD): Support for new discs - New (DVD): Support for new type of "on-demand" discs - Some minor fixes and improvements https://www.redfox.bz/download/SetupAnyDVD.exe |
AnyDVD 8.2.8.0 + DVDFab 10.2.1.5
AnyDVD 8.2.8.0
8.2.8.0 2018 09 20 - Fix: Bug introduced in 8.2.7.0, AnyDVD's unique Cinavia fix was broken for ArcSoft TMT - New (Blu-ray): Invalid drive signature does not cause decryption to abort - New (Blu-ray): Support for new discs - New (DVD): Support for new discs - Some minor fixes and improvements https://www.redfox.bz/download/SetupAnyDVD.exe DVDFab 10.2.1.5 New: Added the support for some new Java protections. New: Added the support to remove the Cinavia watermarks as found on the DVD version of Jigsaw and The Shack. New: Added the conversion profiles for the newly released iPhone XR, iPhone XS and iPhone XS Max in the Ripper and Converter modules. Fix: A problem that the optical drive no longer recognizes the blank medium after the 1st task finishes if there are multiple burning tasks in the queue with ISO files as sources. http://www.dvdfab.cn/download.htm |
AnyDVD 8.2.7.5 Beta + DVDFab 10.2.1.4
AnyDVD 8.2.7.5 Beta
8.2.7.5 2018 09 13 - Fix: Bug introduced in 8.2.7.0, AnyDVD's unique Cinavia fix was broken for ArcSoft TMT - New (Blu-ray): Invalid drive signature does not cause decryption to abort - New (Blu-ray): Support for new discs - New (DVD): Support for new discs - Some minor fixes and improvements http://sandbox.redfox.bz/SetupAnyDVD8275.exe DVDFab 10.2.1.4 New: Added the support for some new Java protections. New: Added the support to identify and access the main title from unprotected Blu-ray ISO files and folders. New: Improved the support for the BluPath feature. http://www.dvdfab.cn/download.htm |
Passkey 9.3.1.9
New: Added the support to identify and access the main title from unprotected Blu-ray ISO files and folders. New: Improved the support for the BluPath feature. http://www.dvdfab.cn/mlink/download.php?g=PASSKEY |
AnyDVD 8.2.7.3 Beta
8.2.7.3 2018 09 03
- Fix: Bug introduced in 8.2.7.0, AnyDVD's unique Cinavia fix was broken for ArcSoft TMT - New (Blu-ray): Support for new discs - New (DVD): Support for new discs - Some minor fixes and improvements http://sandbox.redfox.bz/SetupAnyDVD8273.exe |
DVDFab 10.2.1.3 + AnyDVD 8.2.7.2 Beta
DVDFab 10.2.1.3
Fix: A crash problem when opening DVD discs in certain cases. https://www.dvdfab.cn/mlink/download.php?g=DVDFAB10 AnyDVD 8.2.7.2 Beta 8.2.7.2 2018 09 01 - Fix: Bug introduced in 8.2.7.0, AnyDVD's unique Cinavia fix was broken for ArcSoft TMT - New (Blu-ray): Support for new discs - New (DVD): Support for new discs - Some minor fixes and improvements http://sandbox.redfox.bz/SetupAnyDVD8272.exe |
DeUHD Ultra HD Blu-ray 1.0.3.5 + DVDFab 10.2.1.0
1.0.3.5 08/20/2018 Added support for AACS 2.1 Fury JP version. Please update to the latest version. Support some new discs, check the details from http://deuhd.ru/4k_uhd_info.html Added support for different versions of some titles already on the list. Fixed crash issue in last version. https://www.deuhd.ru/download.html DVDFab 10.2.1.0 New: Added the support for some new Java protections. New: Added the support to remove the Cinavia watermarks as found on the Blu-ray version of Traffik (2018) and the DVD version of Acrimony (2018). Fix: A problem that the File Transfer cannot start up if Maple-Leaf Red or Mixed Blue skin is in use. http://www.dvdfab.cn/download.htm |
Passkey 9.3.1.8 + AnyDVD 8.2.7.1 Beta
Passkey 9.3.1.8
New: Added the support for the new copy protections as found on DVD Traffik, The Big Sick and The Last Flag Flying. New: Added the support to remove the Blu-ray country code at Settings > Blu-ray > Remove Blu-ray Country Code. http://www.dvdfab.cn/mlink/download.php?g=PASSKEY AnyDVD 8.2.7.1 Beta 8.2.7.1 2018 08 19 - Fix: Bug introduced in 8.2.7.0, AnyDVD's unique Cinavia fix was broken for ArcSoft TMT - New (Blu-ray): Support for new discs - New (DVD): Support for new discs http://sandbox.redfox.bz/SetupAnyDVD8271.exe |
DVDFab 10.2.0.9
New: Added the support to remove the Cinavia watermarks as found on the Blu-ray version of The Shallows (2016) and the DVD version of Early Man (2018). New: Added a new utility to download and convert YouTube videos to MP3 tracks. New: Added the support to remove the country code from Blu-rays. Fix: A problem that the No Menu option in the Blu-ray to DVD Converter module, when selected, crashes the program, and if not, still creates menus. Fix: A problem that the custom background feature of the menu templates in DVD Creator module does not work. Fix: A problem that the Fast Forward and Rewind features do not work when previewing Blu-rays under Main Movie mode. http://www.dvdfab.cn/download.htm |
DeUHD Ultra HD Blu-ray 1.0.3.4
1.0.3.4 08/13/2018
AAdded preview feature to check decryption status. Support some new discs, check the details from http://deuhd.ru/4k_uhd_info.html Added support for different versions of some titles already on the list. https://www.deuhd.ru/download.html |
DVDFab 10.2.0.7 + DVDFab 10.2.0.8 Beta
DVDFab 10.2.0.7
Fix: A crash problem when switching output size at the Advanced Settings panel of Blu-ray to DVD Converter module http://www.dvdfab.cn/download.htm DVDFab 10.2.0.8 Beta New: Added the support for some new Java protections. New: Added a new utility to download and convert YouTube videos to MP3 tracks. New: Added the support to remove the country code from Blu-rays. http://www.dvdfab.cn/mlink/download.php?g=DVDFAB10_BETA |
DVDFab 10.2.0.6
New: Added the support to remove the Cinavia watermarks as found on the DVD version of The Commuter.
New: Added a newly designed menu template in the Creator module named The Fleeting Meteor which can be downloaded from the Menu Library. New: Added the support to predefine the output video quality in the Creator modules. Fix: Improved the chapter preview experience. Fix: A problem that some video sources cannot open in certain cases. Fix: A problem that the cropping feature in the Ripper and Converter modules does not work properly in certain cases. Fix: A problem that the AVI files produced by the Ripper modules have incorrect durations and do not play back. http://www.dvdfab.cn/download.htm |
DVDFab 10.2.0.5 Beta
New: Added a newly designed menu template in the Creator module named The Fleeting Meteor which can be downloaded from the Menu Library. New: Added the support to predefine the output video quality in the Creator modules. Fix: Improved the chapter preview experience. Fix: A problem that some video sources cannot open in certain cases. Fix: A problem that the cropping feature in the Ripper and Converter modules does not work properly in certain cases. Fix: A problem that the AVI files produced by the Ripper modules have incorrect durations and do not play back. http://www.dvdfab.cn/mlink/download.php?g=DVDFAB10_BETA |
| Wszystkie czasy w strefie CET. Aktualna godzina: 15:04. |
