-   Zabezpieczenia CD/DVD/Blu-ray (https://forum.cdrinfo.pl/f11/)
-   -   [ARTYKUŁ]Jak wykonać kopię płyt BluRay (https://forum.cdrinfo.pl/f11/artykul-jak-wykonac-kopie-plyt-bluray-95913/)
czary2mary 29.04.2019 11:05
Passkey 9.3.4.3
http://www.dvdfab.cn/mlink/download.php?g=PASSKEY
New: Added the support for some new Java protections.
New: Added the support for the BS4K & CS4K (4K BDAV) contents recorded by Sharp devices.
czary2mary 27.04.2019 08:24
DVDFab 11.0.2.7
https://www.dvdfab.cn/download.htm
New: Added the APE audio conversion profile in the Ripper and Converter modules.
New: Improved the compatibility on non-standard Blu-rays.
New: Improved the Video Downloader utility tool.
Fix: A failure problem when converting certain files with Passthrough processing mode in the UHD Creator module.
Fix: An output file oversize problem in the Blu-ray Ripper module.
czary2mary 20.04.2019 08:46
AnyDVD 8.3.5.0 + Passkey 9.3.4.2 + DVDFab 11.0.2.6
AnyDVD 8.3.5.0
https://www.redfox.bz/download/SetupAnyDVD.exe
8.3.5.0 2019 04 18
- New: PowerDVD 19 is now supported by AnyDVD's unique Cinavia fix
- New (Blu-ray): CloneBD 64 bit is now supported by AnyDVD's Cinavia fix.
It allows to modify the audio data within CloneBD during the copy operation.
CloneBD must be decoding the audio data (downsampling to AC3 must be enabled in CloneBD!)
The AnyDVD fox icon in the Windows notification area will turn purple, if samples are processed
(similar to the PowerDVD and ArcSoft TMT Cinavia patches).
- New (Blu-ray): Supports locally installed protection database
- New (Blu-ray): Support for new discs
- New (Blu-ray): Support for new type of "on-demand" discs
- New (DVD): Support for new discs
- Fix (DVD): IFOProperties 6 error with some titles
Passkey 9.3.4.2
DVDFab 11.0.2.6
New: Added the new conversion profile for Huawei P30 smart phone in the Ripper and Converter modules.
New: Added some new audio conversion profiles in the Ripper and Converter modules.
New: Introduced the new feature to convert an audio file from one format to another in the Converter module.
New: Introduced the free versions of the DVD Copy, DVD Ripper, Blu-ray Copy and Blu-ray Ripper modules.
New: Some minor improvements on GUI and UE.
Fix: A problem that the UHD Ripper module cannot select conversion profiles in certain cases.
czary2mary 19.04.2019 08:26
DVDFab 11.0.2.5
czary2mary 17.04.2019 10:30
AnyDVD 8.3.4.5 Beta + DeUHD Ultra HD Blu-ray 1.0.3.9
AnyDVD 8.3.4.5 Beta
http://sandbox.redfox.bz/SetupAnyDVD8345.exe
8.3.4.5 2019 04 16
DeUHD History
1.0.3.9 04/16/2019
Support some new discs, check the details from http://deuhd.ru/4k_uhd_info.html
Added support for different versions of some titles already on the list.
Fixed some crash problems.
https://www.deuhd.ru/download.html
czary2mary 14.04.2019 07:40
DVDFab 11.0.2.4 + Passkey 9.3.4.1 + AnyDVD 8.3.4.4 Beta
DVDFab 11.0.2.4
New: Added the support to remove the Cinavia watermark as found on the US version of 4K Ultra HD Blu-ray Resident Evil: The Final Chapter (2016).
New: Added the new conversion profiles for some major Huawei smart phones including the Mate X/20/10 series, P20 series, Nova series and more in the Ripper and Converter modules.
New: Added the support to delete the finished tasks without the need of a program restart.
Fix: A crash problem when clearing history in certain cases.
Passkey 9.3.4.1
New: Added the support for a new DVD protection as found on The House with a Clock.
Fix: A failure problem when opening certain Blu-ray discs.
AnyDVD 8.3.4.4 Beta
http://sandbox.redfox.bz/SetupAnyDVD8344.exe
8.3.4.4 2019 04 11
czary2mary 29.03.2019 02:16
DVDFab 11.0.2.2 + Passkey 9.3.4.0
DVDFab 11.0.2.2
New: Added the auto crop feature to the Video Converter module.
Fix: A freeze problem if the Audio Copy option is selected when converting 3D Blu-rays with 3D.MKV.MVC profile.
Fix: A problem that two empty video folders are created in the output directory if 2 separate files 3D format is selected when converting 2D 4K videos to 3D 4K videos in the Video Converter module.
Fix: A problem that conversion fails immediately upon startup under 2-pass encoding method in the Video Converter module.
Fix: A crash problem upon the finish of a single conversion task if there are multiple tasks in the queue in the Video Converter module.
Fix: Improved the user experience of the YouTube to MP3 utility.
Fix: Some minor GUI improvements.
Passkey 9.3.4.0
Fix: Improved the BDFix utility to address the problem that certain Blu-ray sources cannot play on PowerDVD.
Fix: A slow speed problem when ripping adult DVDs to ISO files.
czary2mary 28.03.2019 06:42
AnyDVD 8.3.4.2 Beta
8.3.4.2 2019 03 27
http://sandbox.redfox.bz/SetupAnyDVD8342.exe
czary2mary 23.03.2019 10:38
DVDFab 11.0.2.1
New: Added the support for more DVDs and Blu-rays in the free HD Decrypter.
New: Added the support to remove the Cinavia watermark found on the Blu-ray version of Don***8217;t Be Afraid of the Dark.
Fix: A problem that the Sakura skin cannot be applied.
Fix: A problem that the current conversion will fail if a new source is loaded and the Video Edit panel is opened while that conversion is in progress.
czary2mary 22.03.2019 14:31
DVDFab 11.0.2.0 + Passkey 9.3.3.9
DVDFab 11.0.2.0
New: Added the support to remove the Cinavia watermark found on the DVD version of Trainwreck (2015) and American Ultra (2015).
New: Added the option to retain the HDR 10 contents in certain profiles of the Converter module.
New: Added the conversion profiles for the Samsung Galaxy S10/S10 Plus in the Converter and Ripper modules.
New: Introduced the newly designed sakura skin.
Fix: A problem that using command lines to exit DVDFab does not work properly.
Fix: A conversion failure problem if AC-3/5.1 audio track is selected when ripping the 4K UHD version of Rampage with MKV Passthrough profile.
Fix: A problem that the DTS-HD Master audio does not play back correctly after the Cinavia watermark is removed from the Blu-ray version of La La Land.
Fix: A problem that the Video Converter module does not display the correct runtime for certain TS videos.
Fix: An incomplete conversion problem in the DVD Ripper module.
Fix: A problem that the backup discs of the recorded Korean BDAV discs with multiple titles cannot play back in order.
Fix: A conversion failure problem of the Japanese adult DVDs in the Ripper module.
Passkey 9.3.3.9
czary2mary 15.03.2019 08:43
DVDFab 11.0.1.9 + Passkey 9.3.3.8
DVDFab 11.0.1.9
New: Added the support to remove the Cinavia watermark found on the DVD version of Burlesque and Unfriended.
Fix: A failure problem when opening certain video files.
Fix: A problem that the other display languages except English are missing from YouTube to MP3.
Fix: Some minor UI display issues.
Passkey 9.3.3.8
New: Added the support to rip Japanese adult DVDs to HDDs as ISO files or folders.
czary2mary 12.03.2019 10:46
AnyDVD 8.3.4.1 Beta
8.3.4.1 2019 03 08
http://sandbox.redfox.bz/SetupAnyDVD8341.exe
czary2mary 09.03.2019 06:57
Passkey 9.3.3.7
czary2mary 07.03.2019 08:35
DVDFab 11.0.1.8
New: Added the support for some new Japanese adult DVDs.
Fix: A problem that the subtitles of the UHD Ripper converted videos are improperly positioned.
Fix: A playback repetition problem of the Hi-Fi Audio Converter produced audio files if Split by Chapter is enabled when converting with the Flac Stereo profile.
Fix: A crash problem if the Copy Audio option is enabled at the Advanced Settings panel when converting DVDs containing 3.1 audio tracks.
Fix: A crash problem when converting certain AVI videos with the MKV.Passthrough profile.
czary2mary 25.02.2019 12:10
DVDFab 11.0.1.7 + Passkey 9.3.3.3
DVDFab 11.0.1.7
New: Added the support to remove the Cinavia watermark as found on the Blu-ray version of Take Shelter.
New: Added the PCM codec support to the MKV profile in the Ripper and Converter modules.
New: Added the support to subscribe and automatically download the updated music in YouTube to MP3 utility.
More Info: https://www.dvdfab.cn/faq/?type=youtube_to_mp3#faq_1
New: Added the support to set the output audio quality as 320/256/192/128/96 kbps in YouTube to MP3 utility.
Passkey 9.3.3.3
Wszystkie czasy w strefie CET. Aktualna godzina: 13:53.
