-   Zabezpieczenia CD/DVD/Blu-ray (https://forum.cdrinfo.pl/f11/)
-   -   [ARTYKUŁ]Jak wykonać kopię płyt BluRay (https://forum.cdrinfo.pl/f11/artykul-jak-wykonac-kopie-plyt-bluray-95913/)
czary2mary 08.06.2021 12:53
DVDFab 12.0.3.2 + DVDFab Passkey 9.4.1.3
DVDFab 12.0.3.2
https://www.dvdfab.cn/download.htm
DVDFab 12.0.3.2 Changelog
Fix: A problem that the Menu Settings panel is missing from the UHD to Blu-ray Converter module.
Fix: An installation failure problem when installing other DVDFab products recommended in the Updater window if the display language is Japanese.
https://www.dvdfab.cn/mlink/download.php?g=PASSKEY
Passkey 9.4.1.3 Changelog
New: Added the support for some new Java protections.
czary2mary 01.06.2021 15:13
DVDFab 12.0.3.1
DVDFab 12.0.3.1 Changelog
New: Some improvements on GUI display on 4K displays with high DPI settings.
Fix: A B-Frame conversion problem when converting videos to MKV format on machines installed with NVIDIA Turing graphics card.
czary2mary 21.05.2021 07:42
DVDFab Passkey 9.4.1.2
Passkey 9.4.1.2 Changelog
czary2mary 16.05.2021 06:33
DVDFab 12.0.2.9
DVDFab 12.0.2.9 Changelog
Fix: A failure problem when converting certain Blu-rays to MP4 videos in the Blu-ray Ripper module.
Fix: A crash problem when converting certain DVDs to MP4 videos in the DVD Ripper module.
Fix: A failure problem when switching to DVDFab Mini in certain cases.
Fix: A crash problem when starting up the DRM Removal module in certain cases.
Fix: Some minor changes and improvements.
czary2mary 06.05.2021 07:25
AnyDVD 8.5.4.0
https://www.redfox.bz/download/SetupAnyDVD.exe
8.5.4.0 2021 05 03
- New: PowerDVD 21 is now supported by AnyDVD's unique Cinavia fix
- New: Added PowerDVD 21 info to logfile
- New (Blu-ray): Support for new discs
- New (DVD): Support for new discs
- Change: Desktop icon and menu shortcuts start AnyDVDtray.exe
czary2mary 30.04.2021 10:24
DVDFab 12.0.2.7
DVDFab 12.0.2.7 Changelog
New: Added the support to convert SRT subtitles to IDX format when converting videos in the Video Converter module.
New: Added the support to convert the PCM 24 audios from Blu-rays to PCM 16 audios in the Blu-ray Copy and Blu-ray Ripper modules.
Fix: A problem that the tabs on the upper navigation menu do not respond in certain cases.
Fix: A failure problem when merging DVDs in the DVD Copy module in certain cases.
Fix: A problem that the output DVDs converted from certain Blu-rays contain no audios.
Fix: A problem that the output file size is 0KB when converting certain Blu-rays to MP4 using the MP4.Apple.Prores profile.
Fix: A failure problem when converting certain videos in the Video Converter module.
czary2mary 27.04.2021 11:39
DVDFab 12.0.2.6 + AnyDVD 8.5.3.2 Beta
DVDFab 12.0.2.6
DVDFab 12.0.2.6 Changelog
New: Added some 5K relevant MKV, MP4, MOV and M2TS conversion profiles in the Video Converter and Ripper modules.
Fix: An update failure problem if the OS language is Japanese.
Fix: A freeze problem when upscaling Blu-rays with Enlarger AI on machines installed with certain NVIDIA video cards.
Fix: A failure problem when converting Blu-rays with MKV.H265 profile in the Blu-ray Ripper module.
Fix: A minor GUI display problem when adjusting the width of the Title column on the main interface.
AnyDVD 8.5.3.2 Beta
https://sandbox.redfox.bz/SetupAnyDVD8532.exe
8.5.3.2 2021 04 20
czary2mary 09.04.2021 20:51
DVDFab 12.0.2.4 + AnyDVD 8.5.3.1 Beta
DVDFab 12.0.2.4
DVDFab 12.0.2.4 Changelog
New: Added the support to output FLAC audios in the MP4 relevant profiles in the Ripper and Converter modules.
New: Added two 8K MOV relevant profiles in the Ripper and Converter modules.
AnyDVD 8.5.3.1 Beta
https://sandbox.redfox.bz/SetupAnyDVD8531.exe
8.5.3.1 2021 04 07
czary2mary 02.04.2021 09:19
DVDFab 12.0.2.3 + AnyDVD 8.5.3.0
DVDFab 12.0.2.3
DVDFab 12.0.2.3 Changelog
New: Some improvements on the Enlarger AI conversion engine.
New: Added the support to output ALAC audios when converting with MKV relevant profiles in the Ripper and Video Converter modules.
New: Added the MOV conversion profile in the Ripper and Video Converter modules.
Fix: A freeze problem when converting certain DVDs to Blu-rays with the 32-bit version DVDFab 12.
Fix: A freeze problem when converting certain M2TS videos to MP4 videos with TrueHD audios.
Fix: A problem the output files are still sent to One Drive despite selecting another output path when merging Blu-rays in the Blu-ray Ripper module.
AnyDVD 8.5.3.0
8.5.3.0 2021 04 01
czary2mary 23.03.2021 13:21
DVDFab 12.0.2.1 + DVDFab Passkey 9.4.1.0
DVDFab 12.0.2.1
DVDFab 12.0.2.1 Changelog
New: Some improvements on memory usage when upscaling videos with Enlarger AI.
New: Some improvements on the software stability when upscaling DVDs to Blu-rays with Enlarger AI.
New: Added the support to output FLAC audios in the MKV relevant conversion profiles.
Fix: A failure problem when converting certain DVDs in the DVD Ripper module.
Fix: A failure problem when converting DVDs using the MKV.Apple.ProRes conversion profile in the DVD Ripper module.
Fix: A freeze problem when copying certain 4K Ultra HD Blu-rays with the Full Disc mode in the UHD Copy module.
Fix: A failure problem when converting certain types of videos in the Creator modules.
Fix: A minor GUI display problem.
Passkey 9.4.1.0 Changelog
czary2mary 17.03.2021 20:01
DVDFab 12.0.2.0
DVDFab 12.0.2.0 Changelog
New: Added the support to output 7.1-channel TrueHD audios when converting Blu-rays and 4K Ultra HD Blu-rays containing DTS-HD audios in the Ripper modules.
Fix: A problem that certain conversion profiles appear twice in the profile library when installing a new version over the previous one.
Fix: A freeze problem when converting m2ts videos in the Video Converter module in certain cases.
Fix: A problem that the Volume Up settings at the Advanced Settings panel does not work with the Video Converter module.
czary2mary 03.03.2021 07:25
DVDFab 12.0.1.9
DVDFab 12.0.1.9 Changelog
New: Discontinued the OS support for the Enlarger AI module on older Windows versions, only Windows 10 64-bit is supported now.
New: Added the Apple Prores codec output support in MP4/MKV passthrough conversion profiles.
Fix: A problem that the Clear Opening History feature does not work.
Fix: A problem that the Metadata of the output files by the Ripper module contain messy codes.
Fix: A crash problem upon clicking the Choose Other Titles button in certain cases.
Fix: A problem that the output videos by the MKV.3D.MVC conversion profile in the Blu-ray Ripper module are not 3D.
Fix: A problem that the output videos by the UHD Ripper module contain no Dolby audios.
Fix: A conversion failure problem in the Blu-ray Recorder Ripper module in certain cases.
Fix: A text display problem in the Menu Settings panel of the Blu-ray Creator module.
czary2mary 22.02.2021 21:32
AnyDVD 8.5.2.0
8.5.2.0 2021 02 19
Change (Blu-ray): Removed confusing BD+ dialog
Improved (UHD Blu-ray): Prevent "UHD friendly" drives to "lock" after some minutes of inactivity.
Fix (UHD Blu-ray): Pausing AnyDVD ripper could "lock" "UHD friendly" drives
czary2mary 19.02.2021 14:47
AnyDVD 8.5.1.4 Beta
8.5.1.4 2021 02 18
- Change (Blu-ray): Removed confusing BD+ dialog
- Improved (UHD Blu-ray): Prevent "UHD friendly" drives to "lock" after some minutes of inactivity.
- Fix (UHD Blu-ray): Pausing AnyDVD ripper could "lock" "UHD friendly" drives
czary2mary 08.02.2021 20:51
DVDFab Passkey 9.4.0.9
Passkey 9.4.0.9 Changelog
New: Added the support for some new DVD protections.
Wszystkie czasy w strefie CET. Aktualna godzina: 12:52.
