Passkey 9.2.3.2
New: Added the support for the BD-J protections as found on Jigsaw (Canadian version) and The Hitman***8217;s Bodyguard.
http://www.dvdfab.cn/mlink/download.php?g=PASSKEY |
Passkey 9.2.3.1
New: Added the support for a new BD-J protection as found on My Little Pony.
Fix: Improved the cloud decryption procedures for DVDs. http://www.dvdfab.cn/mlink/download.php?g=PASSKEY |
DeUHD Ultra HD Blu-ray 1.0.2.3
1.0.2.3 03/05/2018
Support some new discs, check the details from http://deuhd.ru/4k_uhd_info.html Added support for different versions of some titles already on the list. https://www.deuhd.ru/download.html |
DVDFab 10.0.8.4
New: Added the support for some new Java protections.
New: Added the support to remove the Cinavia watermarks from the Blu-ray versions of American Assassin and Despicable Me 3. Fix: A problem that the audio channel order is messed up after removing the Cinavia encryptions from certain Blu-rays. Fix: A Cinavia removal failure problem if the selected audio of the Blu-ray contains 3.0 channel. Fix: A freeze problem when converting certain Blu-rays to MP4 videos. Fix: A failure problem when opening certain video files. Fix: A problem that the added Korean external subtitles are not displayed. http://www.dvdfab.cn/download.htm |
Passkey 9.2.2.9
Fix: A failure problem when ripping DVDs to ISO files in certain cases. http://www.dvdfab.cn/mlink/download.php?g=PASSKEY |
DeUHD Ultra HD Blu-ray 1.0.2.2
1.0.2.2 02/26/2018
DeUHD Ultra HD Blu-ray 1.0.2.1
1.0.2.1 02/19/2018
DeUHD Ultra HD Blu-ray 1.0.2.0
1.0.2.0 02/12/2018
Support some new discs, check the details from http://deuhd.ru/4k_uhd_info.html Added support for different versions of some titles already on the list. Added support to upload disc information, which will help to speed up the support for the disc. https://www.deuhd.ru/download.html |
AnyDVD 8.2.2.2 Beta
8.2.2.2 2018 02 09
- New (Blu-ray): Support for new discs - New (UHD Blu-ray): Handle DolbyVision playlists - New (DVD): AI scanner can handle discs without first play pgc - Some minor fixes and improvements - Updated languages http://sandbox.redfox.bz/SetupAnyDVD8222.exe |
Passkey 9.2.2.8
AnyDVD 8.2.2.0
8.2.2.0 2018 02 06
- New: PowerDVD 14 UHD OEM is now supported by AnyDVD's unique Cinavia fix - New (UHD Blu-ray): Added decryption with "UHD friendly" drives (experimental). - New (UHD Blu-ray): Prevent "UHD friendly" drives to "lock" after some minutes of inactivity. - New (Blu-ray): Support for new discs - New (DVD): Support for new discs - Change: Removed drive serial number from status window and logfile - Some minor fixes and improvements https://www.redfox.bz/download/SetupAnyDVD.exe |
DVDFab 10.0.8.1 + AnyDVD 8.2.1.10 beta
DVDFab 10.0.8.1
New: Added the support for some new Java protections. Fix: A crash problem upon software startup in certain cases. http://www.dvdfab.cn/download.htm AnyDVD 8.2.1.10 beta 8.2.1.10 2018 02 05 - New: PowerDVD 14 UHD OEM is now supported by AnyDVD's unique Cinavia fix - New (UHD Blu-ray): Added decryption with "UHD friendly" drives (experimental). - New (UHD Blu-ray): Prevent "UHD friendly" drives to "lock" after some minutes of inactivity. - New (Blu-ray): Support for new discs - New (DVD): Support for new discs - Change: Removed drive serial number from status window and logfile - Some minor fixes and improvements http://sandbox.redfox.bz/SetupAnyDVD82110.exe |
DeUHD Ultra HD Blu-ray 1.0.1.9
1.0.1.9 02/05/2018
DVDFab 10.0.8.0
New: Added the support to remove the Cinavia watermarks from the Blu-ray versions of Rock Dog and Red Turtle, and the DVD version of the American Assassin, Despicable Me 3 and Hitman's Bodyguard. Fix: Improved the metadata feature for DVDs. Fix: The authorization failure problem if users use wireless connection and external hard drives. Fix: The problem that there is no way to set the License Info window not to pop up after software startup. Fix: Some minor changes and improvements. http://www.dvdfab.cn/download.htm |
Passkey 9.2.2.7
| Wszystkie czasy w strefie CET. Aktualna godzina: 15:02. |
