DVDFab x64 10.0.7.3
Na razie ukazała się nowa tylko x64 bit wersja .
Producent zapowiedział ukazanie się wersji x32bit w późniejszym terminie . Fix: A crash problem when opening the BDAV discs in certain cases. http://www.dvdfab.cn/mlink/download.php?g=DVDFAB10_x64 |
AnyDVD 8.2.1.0
8.2.1.0 2017-12-15
New (Blu-ray): Support for new discs New (UHD Blu-ray): Remastering support (speedmenus, remove annoyances, remove UOPs, subtitle movement and transparency, ...) added for unprotected discs or images. New (DVD): Support for new discs New (DVD): Avoid lengthy DVD structure repair for some discs Fix (DVD): Crash during scan of some incorrectly authored discs Fix (DVD): Crash during logfile creation of some incorrectly authored discs Fix (DVD): Crash when ripping multiple discs to folder at the same time Change: Reverted to previous driver for troubleshooting https://www.redfox.bz/download/SetupAnyDVD.exe |
Passkey 9.2.2.1
New: Added the support for some new Java protections.
http://www.dvdfab.cn/mlink/download.php?g=PASSKEY |
DVDFab 10.0.7.2
DeUHD Ultra HD Blu-ray v.1011
Support some new discs, check the details from http://deuhd.ru/4k_uhd_info.html
Added support for different versions of some titles already on the list. Improved the stability of network connection. https://www.deuhd.ru/download/DeUHD1011.exe |
AnyDVD 8.2.0.5 Beta
8.2.0.5 2017 12 09
- New (Blu-ray): Support for new discs - New (DVD): Support for new discs - New (DVD): Avoid lengthy DVD structure repair for some discs - Fix (DVD): Crash during scan of some incorrectly authored discs - Fix (DVD): Crash during logfile creation of some incorrectly authored discs - Fix (DVD): Crash when ripping multiple discs to folder at the same time - Change: Reverted to previous driver for troubleshooting http://sandbox.redfox.bz/SetupAnyDVD8205.exe |
DVDFab 10.0.7.1
New: Added the support to remove Cinavia watermarks from Blu-rays with the Full Disc mode. New: Added the support to remove a new protection as found on the DVD version of Office Christmas Party. New: Added the support to show the progress bar when analyzing sources in Blu-ray Copy module. New: Introduced the Multi-Authorization feature for Single-User licenses. Your account information is required to authorize your current computer. More Info: https://www.dvdfab.cn/purchase-policy.htm1 Fix: The hardware acceleration problem on Windows 10 systems with Intel HD2000/3000 video cards. Fix: A crash problem when converting H265 encoded videos using the MP4.Passthrough profile. Fix: A green screen problem when rendering subtitles with the Ripper module in certain cases. Fix: Some minor changes and improvements. http://www.dvdfab.cn/download.htm |
AnyDVD 8.2.0.4 Beta
8.2.0.4 2017 12 06
- New (Blu-ray): Support for new discs - New (DVD): Support for new discs - New (DVD): Avoid lengthy DVD structure repair for some discs - Fix (DVD): Crash during scan of some incorrectly authored discs - Fix (DVD): Crash during logfile creation of some incorrectly authored discs - Fix (DVD): Crash when ripping multiple discs to folder at the same time - Change: Reverted to previous driver for troubleshooting http://sandbox.redfox.bz/SetupAnyDVD8204.exe |
DeUHD Ultra HD Blu-ray v.1010 + AnyDVD 8.2.0.3 Beta
DeUHD Ultra HD Blu-ray v.1010 DeUHD History 1.0.1.0 12/05/2017 Support some new discs, check the details from http://deuhd.ru/4k_uhd_info.html9 https://deuhd.ru/download.html AnyDVD 8.2.0.3 Beta 8.2.0.3 2017 12 05 - New (Blu-ray): Support for new discs - New (DVD): Support for new discs - Fix (DVD): Crash during scan of some incorrectly authored discs - Fix (DVD): Crash during logfile creation of some incorrectly authored discs - Fix (DVD): Crash when ripping multiple discs to folder at the same time - Change: Reverted to previous driver for troubleshooting http://sandbox.redfox.bz/SetupAnyDVD8203.exe |
DVDFab 10.0.6.9 Beta + Passkey 9.2.2.0 + AnyDVD 8.2.0.2 Beta
New: Added the support for some new Java protections. New: Added the support to remove Cinavia watermarks from Blu-rays with the Full Disc mode. New: Added the support to remove a new protection as found on the DVD version of Office Christmas Party. New: Added the support to show the progress bar when analyzing sources in Blu-ray Copy module. New: Introduced the Multi-Authorization feature for Single-User licenses. Your account information is required to authorize your current computer. More Info:https://www.dvdfab.cn/purchase-policy.htm Fix: The hardware acceleration problem on Windows 10 systems with Intel HD2000/3000 video cards. Fix: A crash problem when converting H265 encoded videos using the MP4.Passthrough profile. Fix: A green screen problem when rendering subtitles with the Ripper module in certain cases. Fix: Some minor changes and improvements. http://www.dvdfab.cn/mlink/download.php?g=DVDFAB10_BETA Passkey 9.2.2.0 New: Added the support for some new Java protections. http://www.dvdfab.cn/mlink/download.php?g=PASSKEY AnyDVD 8.2.0.2 Beta 8.2.0.2 2017 11 30 - New (Blu-ray): Support for new discs - Fix (DVD): Crash during scan of some incorrectly authored discs - Fix (DVD): Crash during logfile creation of some incorrectly authored discs - Fix (DVD): Crash when ripping multiple discs to folder at the same time - Change: Reverted to previous driver for troubleshooting http://sandbox.redfox.bz/SetupAnyDVD8202.exe |
DVDFab x64 10.0.6.8
Producent zapowiedział ukazanie się wersji x32bit w późniejszym terminie . New: Added the support for some new Java protections. New: Added the support to remove the Cinavia watermark found on the DVD version of By The Sea. New: Added the support to collect the Meta Info of DVD sources. New: Improved the support to collect the Meta Info of Blu-ray sources. New: Improved the support to scan the BDInfo for the 4K Ultra HD Blu-ray sources. Fix: A problem that the copied main movie of a 4K Ultra HD Blu-ray does not play back in certain cases. Fix: A crash problem when converting certain Blu-ray sources using MP4/MKV profiles. Fix: A crash problem when converting to MP4/MKV profiles using higher bitrate output and CUDA encoder in certain cases. Fix: A crash problem when converting the interfaced sources to the H265 profiles with CUDA encoder in certain cases. Fix: Some minor changes and improvements. http://www.dvdfab.cn/mlink/download.php?g=DVDFAB10_x64 |
DVDFab x64 10.0.6.7 Beta + Passkey 9.2.1.8
Na razie ukazała się nowa tylko x64 bit wersja . Producent zapowiedział ukazanie się wersji x32bit w późniejszym terminie . New: Added the support for some new Java protections. New: Added the support to remove the Cinavia watermark found on the DVD version of By The Sea. New: Added the support to collect the Meta Info of DVD sources. New: Improved the support to collect the Meta Info of Blu-ray sources. New: Improved the support to scan the BDInfo for the 4K Ultra HD Blu-ray sources. Fix: A problem that the copied main movie of a 4K Ultra HD Blu-ray does not play back in certain cases. Fix: A crash problem when converting certain Blu-ray sources using MP4/MKV profiles. Fix: A crash problem when converting to MP4/MKV profiles using higher bitrate output and CUDA encoder in certain cases. Fix: A crash problem when converting the interfaced sources to the H265 profiles with CUDA encoder in certain cases. Fix: Some minor changes and improvements. http://www.dvdfab.cn/mlink/download....FAB10_x64_BETA Passkey 9.2.1.8 New: Added the support for some new Java protections. http://www.dvdfab.cn/mlink/download.php?g=PASSKEY |
DVDFab x64 10.0.6.6
Producent zapowiedział ukazanie się wersji x32bit w późniejszym terminie . Fix: Fixed the problem that the videos converted by the activated UHD Ripper still have DVDFab watermark logo. http://www.dvdfab.cn/mlink/download.php?g=DVDFAB10_x64 |
AnyDVD 8.2.0.0
8.2.0.0 2017 11 13
- New (Blu-ray): Support for new discs - New (DVD): Support for new discs - New: Delayed driver disable, so Windows will receive a disc insertion event on AnyDVD exit - Change: Avoid reading TOC of non-CD media - Change (Blu-Ray): Avoid reading physical layout - Fix: Setting drive speed still didn't work with some drives. https://www.redfox.bz/download/SetupAnyDVD.exe |
DeUHD Ultra HD Blu-ray v.1007
Added "Create an Account" option in the right click menu of the system tray icon Improved the decryption process. https://www.deuhd.ru/download/DeUHD1007.exe |
| Wszystkie czasy w strefie CET. Aktualna godzina: 15:04. |
