DVDFab 10.0.0.3 Alpha version
New: Added the support for some new Java protections. New: Introduced the DVDFab Mini, a simplified version of the Copy and Ripper modules allowing users to easily and quickly copy or convert DVDs & Blu-rays with the least steps possible. Note that the user-saved custom conversion profiles in the Ripper module shall be imported automatically to DVDFab Mini by default. More info: http://www.dvdfab.cn/manual/introduction/DVDFab-Mini New: Improved the support for mkv conversion. Fix: Some minor changes and improvements. http://www.dvdfab.cn/mlink/download....DVDFAB10_Alpha |
DVDFab 9.3.2.0 beta
DVDFab 9.3.2.0
http://www.dvdfab.cn/mlink/download.php?g=DVDFAB9_BETA New: Added the support for some new Java protections. New: Added the support for some new copy protections as found on certain Japanese adult DVDs. New: Improved the support for the DVD Cloud Decryption Service. New: Added the support to remove the Cinavia watermarks found on Still Alice, Her (2013), Kill Your Darlings, Blue Jasmine, Popstar: Never Stop Never Stopping and Inside Llewyn Davis. Fix: A crash problem when opening DVD sources in certain cases. |
AnyDVDHD 8.0.5.3 Beta
http://sandbox.redfox.bz/SetupAnyDVD8053.exe
8.0.5.3 2016 10 28 - New (Blu-ray): Support for new discs - New (DVD): Support for new discs - Testing (Blu-ray 4k): Show supported AACS version of drive - Some fixes and improvements |
AnyDVD HD 8.0.5.2 beta
http://sandbox.redfox.bz/SetupAnyDVD8052.exe
8.0.5.2 2016 10 26 - New (Blu-ray): Support for new discs - New (DVD): Support for new discs - Testing (Blu-ray 4k): Show supported AACS version of drive - Some fixes and improvements |
DVDFab 10
DVDFab 10.0.0.1 Alpha version
New: Introduced the new feature "Cloud Decryption Service" to speed up DVD analysis and decryption. More Info: http://www.dvdfab.cn/cloud_decryption.htm New: Added the support for some new Java protections. New: Improved the support for H265 conversion. New: Added the support to remove the Cinavia watermarks found on Third Person, Kingsglaive: Final Fantasy XV, The Huntsman: Winter's War, Ghost Rider: Spirit of Vengeance, Larry Crowne, Ratchet & Clark and Mr. Turner. New: Added the support to output both AAC and AC3 audio tracks when converting to mp4/mkv profiles. Fix: A problem that the Burn Again function does not work correctly. Fix: A problem that the output file name cannot be changed in Ripper and Video Converter. Fix: A failure problem when converting DVD sources to mp4 videos with rendered subtitles in certain cases. Fix: A problem that the task is not deleted after the source is ejected. Fix: A problem that the task status does not update when cancelling all the tasks in certain cases. Fix: A problem that the output information does not update when switching the profile in Ripper. Fix: A problem that the failed task cannot be deleted from Task Queue Manager in certain cases. Fix: Improved the support for Archived Task. Fix: Some minor changes and improvements. http://www.dvdfab.cn/mlink/download....DVDFAB10_Alpha DVDFab 10.0.0.2 Alpha version New: Added the support to allow DVDFab Remote mobile app to check the real-time task status. More Info: http://www.dvdfab.cn/manual/introduction/DVDFab-Remote New: Improved the conversion speed in the Ripper module in 64-bit Windows systems when using software decoding and encoding. Fix: A problem that the Clone feature does not work in the Copy module. Fix: A failure problem when converting DVDs/Blu-rays to MP4 videos with CUDA enabled in certain cases. Fix: Improved the support for Task Queue Manager. Fix: Improved the Merge feature in the Ripper and Video Converter modules. Fix: Some minor changes and improvements. http://www.dvdfab.cn/mlink/download....DVDFAB10_Alpha |
DVDFab Platinum 9.3.1.9
Fix: A problem that certain anti-virus products, like Bitdefender, give BluPath.exe false positive alert.
Fix: A failure problem when converting DVDs/Blu-rays to mp4 videos with CUDA enabled in certain cases. Fix: A problem that the Merge feature does not work when outputting AAC audios in MP4 and MKV profiles. Fix: Some minor changes and improvements. http://www.dvdfab.cn/download.htm |
DVDFab Platinum 9.3.1.8
Duża aktualizacja \ dodane " Cloud Decryption Service" czyli klucze DVD będą również w bazie metadanych na serwerze firmy ... http://www.dvdfab.cn/cloud_decryption.htm New: Introduced the new feature "Cloud Decryption Service" to speed up DVD analysis and decryption. New: Added the support for some new Java protections. New: Improved the support for H265 conversion. New: Added the support to remove the Cinavia watermarks found on Black Sea, Wild Tales (2014), Neighbors 2: Sorority Rising, Oldboy (2013), Pride and Prejudice and Zombies, Third Person, Kingsglaive: Final Fantasy XV, The Huntsman: Winter's War, Ghost Rider: Spirit of Vengeance, Larry Crowne, Ratchet & Clark and Mr. Turner. New: Added the support to output both AAC and AC3 audio tracks when converting to mp4/mkv profiles. Fix: A failure problem when converting DVD sources to mp4 videos with rendered subtitles in certain cases. Fix: A problem that the converted result is not interlaced after unchecking the Deinterlacing option at Video Edit settings in Video Converter. Fix: Some minor changes and improvements. http://www.dvdfab.cn/download.htm |
AnyDVD HD 8.0.5.1 Beta
8.0.5.1 2016 10 18
- New (Blu-ray): Support for new discs - Testing (Blu-ray 4k): Show supported AACS version of drive http://sandbox.redfox.bz/SetupAnyDVD8051.exe Pierwsze podejście do kluczy AACS-2 (Ultra HD\4 K)..:) |
FairMount Beta 1.1 2016r.
Ukazał się niedawno nowy darmowy program deszyfrujący :spoko:
Zasada działania podobna jak w pozostałym oprogramowaniu czyli deszyfracja w czasie bieżącym . Deszyfruje zabezpieczenia CD Digital Audio(CDDA)\DVD/CPRM/CPPM/Blu-ray/BDAV\ \ odblokowuje zablokowane czy też zabronione operacje (UOP) . Wersja beta 1.1 na dziś posiada suport maksymalnie dla kluczy AACS MKB v31....ale mam nadzieję że będzie lepiej .. strona programu : https://fairmountw.github.io/ program : FairMount 1.1.0 Kod:
ChangelogZałącznik 82504 |
Passkey 9.0.0.6.
Passkey 9.0.0.6.
http://www.dvdfab.cn/mlink/download.php?g=PASSKEY New: Added the support for some new JAVA protections. |
AnyDVD (HD) 8.0.5.0 2016 10 12
- New (Blu-ray): Support for new discs - New (Blu-ray): Improved AnyDVD's unique Cinavia fix for PowerDVD 16 - New (Blu-ray): Added feature, which helps non-licensed Blu-ray players (Kodi, VLC, Media Players, ...) to pick the correct playlist for the main feature - New (DVD): Support for new discs https://www.redfox.bz/download.html DVDFab 9.3.1.7 Beta 2016 10 12 New: Added the support for some new Java protections. New: Improved the support for H265 conversion. New: Added the support to remove the Cinavia watermarks found on Third Person, Kingsglaive: Final Fantasy XV, The Huntsman: Winter's War, Ghost Rider: Spirit of Vengeance, Larry Crowne, Ratchet & Clarkand Mr. Turner. New: Added the support to output both AAC and AC3 audio tracks when converting to mp4/mkv profiles. Fix: A failure problem when converting DVD sources to mp4 videos with rendered subtitles in certain cases. Fix: A problem that the converted result is not interlaced after unchecking the Deinterlacing option at Video Edit settings in Video Converter. Fix: Some minor changes and improvements. http://www.dvdfab.cn/mlink/download.php?g=DVDFAB9_BETA DVDFab 10.0.0.0 Alpha version Oczywiście wersja nie jest w pełni funkcjonalna -posiada wiele niedoskonałości\błędów w układzie interfejsu i jak i działaniu ;...nie ma możliwości korzystać z bazy metadanych DVDFab \ również funkcja zapisu płyt może działać z błędami \ wersja dostępna tylko w jeżyku angielskim . Całkowicie nowy interfejs GUI\Każde zadanie dla Blu-ray Copy / Ripper, DVD Ripper i Video Converter będą uruchamiane w osobnym procesie, co sprawia, DVDFab jest bardziej stabilny\ również na mocnych maszynach można będzie wykonywać kilka zadań na raz .... DVDFab 10 współistnieje z aktualnymi wersjami DVDFab 9, zostanie on zainstalowany w innym katalogu tak że można używać dwóch wersji 9 i 10. http://www.dvdfab.cn/mlink/download....DVDFAB10_Alpha |
DVDFab Platinum 10
Ilość załączników: 2
Fengtao Software Inc. producent pakietów DVDFab\DVDFab PassKey oficjalnie potwierdziła premierę w najbliższym czasie DVDFab Platinum 10....
Załącznik 82174 Załącznik 82175 |
DVDFab Passkey 9.0.0.5
Fix: A crash problem when opening Blu-ray discs on Windows Server 2008 R2. |
@grzeniu - bez Ciebie i Twojego uporu nie byłoby tego artykułu....;) :spoko: :piwo:
Znam osoby które by nie zasnęły jak by nie miały kopii swoich koncertów na półce...wydają taką kasę na nowości że koszty związane z tworzeniem kopii zapasowej są dla nich marginalne...;) Z pewnych względów niektóre informacje "techniczne" nie mogły być zawarte w artykule.. Ceny większości programów ciągle się zmieniają ...jest dzień że pakiet DVDFab Platinum kosztuje 199$ by następnego kosztować 399$..... dlatego uznałem że wystarczą linki do programów gdzie zawsze jest aktualna oferta .... |
Kupe roboty wykonałeś :spoko: :respect:
Widzę jednak, że cały ten temat kopiowania BD (zabezpieczonych) to droga przez mękę. Uzbroić się w skuteczny pakiet deszyfrująco-nagrywający, który jest komercyjny i wcale nie tani, a potem ciągłe aktualizacje tego....żeby sobie skopiować płytkę, to jest wyzwanie dla masochistów. Albo też świetny sposób na piracenie dla zarobku, bo dla zwykłego szaraczka nieopłacalne. Tak czy owak kawał wiedzy w tym artykule zawarłeś. I to jest najcenniejsze - wiedza. PS Trochę mi zabrakło w artykule informacji, albo mi umknęło, jaki jest koszt licencji softu i dlaczego niezbędne są legalne wersje a nie z cukierkami. No ale to już można dopowiedzieć choćby w tym temacie, do którego jest link w artykule. |
| Wszystkie czasy w strefie CET. Aktualna godzina: 15:09. |
