DVDFab 10.0.2.7
New: Introduced the DVD Cinavia Removal module.
More Info: http://www.dvdfab.cn/dvd-cinavia-removal.htm New: Introduced the Blu-ray Cinavia Removal module. More Info: http://www.dvdfab.cn/blu-ray-cinavia-removal.htm New: Starting from this version, the former CinaviaRemoval HD is renamed as DVD & Blu-ray Cinavia Removal, a bundle package covering the newly introduced DVD Cinavia Removal and Blu-ray Cinavia Removal. However, as promised previously, all the existing CinaviaRemoval HD customers will get both DVD Cinavia Removal and Blu-ray Cinavia Removal totally for free. More Info: http://www.dvdfab.cn/dvd-blu-ray-cinavia-removal.htm New: Add the support to remove the Cinavia watermarks found on the DVDs including Kick Ass 2, Blair Witch, Dirty Grandpa, Everest, Hell or High Water, Jason Bourne, Jurassic World, The Last Witch Hunter, Minions (English Audio Track), The Hunger Games: Mockingjay Part 2, Popstar: Never Stop Never Stopping, The Purge: Election Year, Sicario and The Secret Life of Pets. New: Improved the support for the conversion engine. Fix: Improved the support for the new installer program. Fix: Some minor changes and improvements. http://www.dvdfab.cn/mlink/download.php?g=DVDFAB_CNT |
DVDFab 10.0.2.6 Beta + Passkey 9.1.1.0
New: Introduced the DVD Cinavia Removal module. More Info: http://www.dvdfab.cn/dvd-cinavia-removal.htm New: Introduced the Blu-ray Cinavia Removal module. More Info: http://www.dvdfab.cn/blu-ray-cinavia-removal.htm New: Starting from this version, the former CinaviaRemoval HD is renamed as DVD & Blu-ray Cinavia Removal, a bundle package covering the newly introduced DVD Cinavia Removal and Blu-ray Cinavia Removal. However, as promised previously, all the existing CinaviaRemoval HD customers will get both DVD Cinavia Removal and Blu-ray Cinavia Removal totally for free. More Info: http://www.dvdfab.cn/dvd-blu-ray-cinavia-removal.htm New: Add the support to remove the Cinavia watermarks found on the DVDs including Kick Ass 2, Blair Witch, Dirty Grandpa, Everest, Hell or High Water, Jason Bourne, Jurassic World, The Last Witch Hunter, Minions (English Audio Track), The Hunger Games: Mockingjay Part 2, Popstar: Never Stop Never Stopping, The Purge: Election Year, Sicario and The Secret Life of Pets. New: Improved the support for the conversion engine. Fix: Improved the support for the new installer program. Fix: Some minor changes and improvements. http://www.dvdfab.cn/mlink/download.php?g=DVDFAB10_BETA Passkey 9.1.1.0 New: Improved the support for Blu-ray BluPath. http://www.dvdfab.cn/mlink/download.php?g=PASSKEY |
AnyDVD HD 8.1.0.0
8.1.0.0 2017 03 01
New (Blu-ray): Internet connection is no longer required for many discs. New (Blu-ray): Support for new discs New (DVD): Support for new discs New: PowerDVD 12 build 7107 is now supported by AnyDVD's unique Cinavia fix New: PowerDVD 13 build 7012 is now supported by AnyDVD's unique Cinavia fix Some minor fixes and improvements https://www.redfox.bz/download/SetupAnyDVD.exe |
DVDFab 10.0.2.5
New: Added the support for some new Java protections. New: Added the support to remove the Cinavia watermarks found on Pompeii (2014) and Deepwater Horizon. New: Added the support for the iOS version of DVDFab Remote. For iOS: https://itunes.apple.com/us/app/dvdf...5221?ls=1&mt=8 For Android: https://goo.gl/AHRyfS New: Introduced new setup and uninstallation programs. Note that installing this version shall automatically remove the previous installed version. Fix: Some minor changes and improvements. http://www.dvdfab.cn/mlink/download.php?g=DVDFAB_CNT |
DVDFab 10.0.2.4 Beta
For iOS: https://itunes.apple.com/us/app/dvdf...5221?ls=1&mt=8 For Android: https://goo.gl/AHRyfS New: Added the support for some new Java protections. New: Added the support to remove the Cinavia watermarks found on Pompeii (2014) and Deepwater Horizon. New: Added the support for the new setup languages including Norwegian, Swedish, Portuguese, Dutch, Polish, Russian, Czech, Spanish, Hungarian and Italian. Fix: Fixed the setup problem when installing on Czech and French systems. Fix: Some minor changes and improvements. http://www.dvdfab.cn/mlink/download.php?g=DVDFAB10_BETA |
AnyDVD HD 8.0.9.6
8.0.9.6 2017 02 21
- New (Blu-ray): Internet connection is no longer required for many discs. - New (Blu-ray): Support for new discs - New (DVD): Support for new discs - New: PowerDVD 12 build 7107 is now supported by AnyDVD's unique Cinavia fix - New: PowerDVD 13 build 7012 is now supported by AnyDVD's unique Cinavia fix - Some minor fixes and improvements This version should support the "new UK DVD protection" (found on some newer UK DVD releases). There might be some regression issues with older titles, please report any problems. http://sandbox.redfox.bz/SetupAnyDVD8096.exe |
Ta strona wygląda u mnie podobnie, tzn. wszystkie znaki diakrytyczne są zastępowane przez znaki zapytania. Dla czytelności tekstów warto byłoby to poprawić, bo z tego wynika, że w przeglądarce nie można już tego zmienić.
Co do najnowszego AnyDVD 8.0.9.5 - to najpewniej zrobili tak jak DVDFab - tylko najnowsze klucze deszyfrujące BluRay wymagają pobrania z serwerów firmy .
Co do poradnika to programy deszyfrujące wymagane są zgrania materiału - dla zapisu nie są już wymagane . Co do wyświetlania poradnika - u siebie sprawdziłem na IE\Chrome\FireFox - u mnie bez problemów .. Problem dotyczy tylko polskich znaków -ale to dotyczy całego forum chyba Wstaw screen jak wyglądają problemy u Ciebie . Załącznik 87233 |
Czy należy z tego rozumieć, że baza danych zabezpieczeń znajduje się na dysku?
A wracając do poradnika, to rozumiem, że powyższe programy są potrzebne do wykonania obrazu płyty na dysku, natomiast samo wypalenie nośnika można wykonać dowolnym programem, takim jak np. Nero? PS. Nie wiem dlaczego wszystkie poradniki tego forum strasznie mi się "wykrzaczają", w każdej przeglądarce - nie mogę dopasować odpowiedniego kodowania tekstu. Ta uwaga nie dotyczy tego forum czy strony głównej portalu, ale tylko poradników. |
AnyDVD HD 8.0.9.5
8.0.9.5 2017 02 19
- New (Blu-ray): Internet connection is no longer required for many discs. - New (Blu-ray): Support for new discs - New (DVD): Support for new discs - New: PowerDVD 12 build 7107 is now supported by AnyDVD's unique Cinavia fix - New: PowerDVD 13 build 7012 is now supported by AnyDVD's unique Cinavia fix - Some minor fixes and improvements This version should support the "new UK DVD protection" (found on some newer UK DVD releases). There might be some regression issues with older titles, please report any problems. http://sandbox.redfox.bz/SetupAnyDVD8095.exe |
Passkey 9.1.0.8
New: Added the support for the new copy protection found on DVD American Pastoral.
DVDFab 10.0.2.3 Beta
FairMount Beta 1.1 |
Niestety link do pobrania FairMount Beta 1.1 już jest nieaktywny, przynajmniej na stronie https://fairmountw.github.io/
| Wszystkie czasy w strefie CET. Aktualna godzina: 13:53. |
