-   -   Foobar2000 vs.Winamp (https://forum.cdrinfo.pl/f113/foobar2000-vs-winamp-19062/)
Qbi@k 23.06.2008 00:45
Postaram sie aktualnie postowac w temacie ;)
joujoujou 23.06.2008 00:17
I ci***261;gle tylko beta i beta. :mruga:
Qbi@k 22.06.2008 23:49
foobar2000 v0.9.5.4 beta 1
Changelog:
  • Ability to view/edit queries used to create autoplaylists.
  • Media Library Search: queries using ***8220;SORT BY***8221; create always-sorted autoplaylists by default.
  • File format handling updates:
    • Security updates to Vorbis, Speex, FLAC and WavPack libraries.
    • Fixed a rare Ogg seeking accuracy bug.
    • Improved MP4 parser security.
  • Converter improvements:
    • No longer aborts the entire operation when one of queued tracks can't be processed.
    • Optional status log popup after conversion.
  • Album List: ability to select multiple items at once by holding shift or control keys.
  • New built-in DSPs: Crossfader, Skip Silence.
http://foobar2000.pl/index.php?showtopic=4426
Qbi@k 09.02.2008 19:29
[fb2k] foobar2000 v0.9.5.1 beta 1
Improvements to new Default User Interface:
- New built-in Media Library Search dialog, with advanced autoplaylist creation features.
- Configurable left/center/right alignment of custom columns in Playlist View.
- Usability: switching layouts now flashes labels to reduce user confusion.
- Ability to customize toolbar buttons.
- New: Warning popup when trying to close foobar2000 while tasks such as conversion or ReplayGain scan are active.
- Various UI responsivity improvements and speed optimizations; much faster Album List refresh with large libraries.
- Usability: positions of various dialogs are now remembered, relative to their parent windows.
- Properties dialog: ***8220;Tools***8221; button, ***8220;Automatically Fill Values***8221; can now use clipboard as source.
- Converter clean-ups, ability to manually edit commandline encoder executable paths through Advanced Preferences.
- WMA handling bug fixes, ability to store arbitrary metadata fields in WMA tags.
- ID3v2 tagging compatibility improvements.
- Various bug fixes.
http://foobar2000.pl/index.php?showtopic=4161
Arepo 06.01.2008 03:55
Napisany przez Qbi@k (Post 880692)
Jasne ;) Niektorzy wola wybrac playliste z rozwijanej listy, z kolumny, albo z zakladek. W kazdym przypadlu jest duza roznica. Rownie dobrze mozna by to robic przez wpisywanie komend tekstowych do konsolii - efekt byl by przeciez taki sam :szczerb:
dla mnie nie ma różnicy, to kwestia przyzwyczajenia się tylko i wyłącznie ...
gdyby był player z wyborem playlisty z linii poleceń to z pewnością część użytkowników okrzyknęła by go super profesjonalnym, który główny nacisk kładzie na jakość dźwięku a nie łatwość obsługi :D
loki7777 05.01.2008 10:40
mi sie w 0.95 nie podoba ze nie ma skrotow pod nawigajca (ff, stop, play) i ze trzeba robic to samemu:(poza tym wsio ok:)
Qbi@k 05.01.2008 10:17
Napisany przez andy (Post 880653)
@Qbi@k moim zdaniem przesadzasz z tymi por***243;wnaniami.
Porownanie bardzo trafione ||
Napisany przez Arepo (Post 880651)
spos***243;b wyboru playlisty jest przecie***380; kompletnie nieistotny
andy 05.01.2008 05:54
Arepo 05.01.2008 04:55
sposób wyboru playlisty jest przecież kompletnie nieistotny ***8211; efekt jest identyczny , co to za różnica czy mamy zakładkę czy okno ze spisem ;)
niedługo zaczniemy rozmyślać nad wyższością tej samej opcji ale raz włączanej przyciskiem a raz aktywowanej przez zaznaczenie kratki, obłęd :szczerb:
Qbi@k 05.01.2008 02:56
Moze chodzi o zakladki takie jak w FF/Operze? :P To, ze w Winampie mozna miec nawet wlasne playlisty to bardzo dobrze ||
:D :spoko:
Arepo 05.01.2008 01:40
Napisany przez nimal (Post 880639)
wlasnie siedze na cudzym kompie z winampem i bez foobara
jako ze komp kolegi, to mu instalowac nic nie chce
i cierpie strasznie - toz ten program sie nawet oddzielnych list na oddzielnych zakladkach nie nauczyl obslugiwac...
oj oj oj ;)
Załącznik 44680
pozdrawiam ||
nimal 05.01.2008 00:55
Qbi@k 04.01.2008 23:23
Hehe :P Sprytnie :>
Dla zainteresowanych:
[Tutorial] foobar2000 0.9.5 - Pierwsze kroki (konfiguracja od podstaw)
Czyli jak zmieni***263; wygl***261;d i stworzy***263; sw***243;j pierwszy w***322;asny konfig :)
Arepo 04.01.2008 22:48
Napisany przez Qbi@k (Post 880525)
foobar2000 = FireFox
taki dziurawy :D
pozdrawiam ||
Qbi@k 04.01.2008 21:08
Winamp = IE 6.0 / 7.0
Wszystkie czasy w strefie CET. Aktualna godzina: 07:30.
