#2221 |
Data rejestracji: 18.11.2004
tengu - ciekawe kiedy się ktoś za niewo weźmie
oby jak najszybciej
#2222 |
Hitokiri Battousai
Data rejestracji: 14.09.2004
:piwko:
bo jakoś nie mam ochoty być królikiem doświadczalnym ![]() Biosy to jeszcze dla mnie temat dość śliski
#2223 | |
Data rejestracji: 17.12.2002
.Dodam to: Use this as a guideline for good discs: PI (Parity Inner): No larger areas on the disc should exceed 280 PI errors, do not worry too much about high single spikes that exceeds 280. PO (Parity Outer): No larger areas on the disc should exceed 32 PO (actually PI uncorrectable) errors, do not worry too much about high single spikes that exceeds 32. (Note that this is not completely correct according to the standards, but is still a good guideline, read the first technical post if you wonder why this is not a 100% correct way of reading the results compared to the standards). A guideline is to calculate the Parity Inner Uncorrectable errors to 8 ECC sum, which is max 32 (4 x 8) Parity Inner uncorrectable errors, but now we can***8217;t be sure if one of the 8 ECC blocks exceeds the specifications. But if the result exceeds 32 PI uncorrectable errors we know that at least one block have more than 4 PI uncorrectable errors. But if the PO error amount is between 5 and 32 there may still be a block that exceeds the standards. But what makes a disc unreadable? A PO uncorrectable error will make the disc unreadable, but K-Probe does not display the PO uncorrectable errors. I jeszcze to jest ciekawe (ile to by trwało ):So to get results directly comparable to the standards you have to scan a disc twice at 1X reading speed: 1 time with PI/PO sum set to 8 ECC to get a result comparable to the 280 PI errors per 8 blocks standard. 1 time with PI/PO sum set to 1 ECC to get a result comparable to the MAX 4 PI Uncorrectable (Called PO in K-Probe) per block standard. POs are now renamed PIF in Kprobe2 and CDSpeed3 this doesnt change the meaning just a change in terminology. It stands for Parity Inner Failures. Na koniec małe moje podsumowanie: dobrze, żeby PI nie przekraczało 280 a PIF 4 ale nawet jeśli przekracza to nie znaczy, że dvd jest nieczytelna tylko, że przekracza standard i wymaga lepszej korekcji błędów. A wiadomo, że praktycznie wszystkie urządzenia dvd mają lepszą korekcję błędow niż ta opisana w "standardzie" Ech, ale się naczytałem, a jaki mądry będe teraz. Slawekj
Mozilla Firefox + The Bat! IniemamocnI ![]() Benq sobie radzi . Pionek
Ostatnio zmieniany przez Conti : 04.12.2004 o godz. 17:59 |
#2224 |
za dużo kombinowania z tymi biosami, za dużo możliwości
sam ostatnio zmieniłem z BS0C na BS0K + omni i przyznaje że verbatim nagrywa sie dużo lepiej PI max 8 PIF max 2
BenQ DW1640
#2225 |
Data rejestracji: 04.12.2004
a teraz ciekawostka. Zmienilym dysk na 250 gb, na ktorym mam winde sp2 , nero i kilka image. Nagralem Szrekusia na platinum x6 na Litku1633 BSOR. Test na predkosci 4x i zobaczcie jaka roznica
Co myslicie ? CO jest powodem?
#2226 | |
Na to czekałem. Jak rozpisywałem się o zależności konfiguracji na jakość wypalania to było chura... że sobie coś wymyślam. A czas ... pokazuje. To dobry przykład. Mam wiele teorii popartych testami. Ale każdy ma swoje zdanie. Szkoda. Najważniejsze to błędy Jitter. Tych błędów nie można sprawdzić na LiteOn'ie. A to one głównie decydują czy płytka będzie poprawnie czytana na innych napędach i DVD-Player'ach. Kombinuj dalej. To prawdziwa frajda i doświadczenia przybywa.
Ostatnio zmieniany przez slawekj : 04.12.2004 o godz. 18:04 |
#2227 |
Hitokiri Battousai
Teraz jest nieźle, a nawet bardzo dobrze - milłego palenia, widocznie u ciebie BSOR jest najlepszym biosem i może transfer między dyskiem a nagrywarką (w poprzednim był gorszy) szwankował (w ile nagrywałeś np x8 lub x4? [około] )
#2228 |
transfer z poprzedniego dysku byl OK
Robilem defragmentacje, bufer nie spadal Zrobie jeszcze jedna rzecz. Przekopiuje image z tego dysku , ktory nagralem i wykres jest powyzej na tamten i nagram pod tamtym systemem i sprawdzimy czy to wina transferu dysku
#2229 |
a teraz Spidermanek 2 , wczesniej juz pokazywany w wykresie DVD1.jpg ponizej przy predkosci odczytu x4 . Zaraz zrobie z niego kopie na Platinum x8 przy predkosci x8 i zoribe wykresik.
Ostatnio zmieniany przez Paul967 : 04.12.2004 o godz. 18:04 |
#2230 |
Hitokiri Battousai
Czemu wkleiłeś ten sam obrazek 2 razy ??
#2231 |
słuchajcie wielki szacuneczek dla Was ale jak możecie pisać że to są dobre wyniki
PI 48 i PIF 3 - to są dobre wyniki ?? Wiem że może być dużo gorzej no ale !
BenQ DW1640
#2232 |
zarazilem kumpla testami, przy predkosci x4 testowal film nagranyy na plycie AXE produkowane na zjlecenie znajomego. Wydaje mi sie ,ze PI jest za wysokie, takto super.
#2233 | |
#2234 |
Moim zdaniem najlepsze są płytki Verbatim i TDK, Platinim też niczego sobie,
a słyszeliście o czymś takim jak płytka VOBIS +R x4 właśnie ją testuje zaraz wyniki
BenQ DW1640
#2235 | ||
Nie ma takiej samej płytki. Cytat:
Ostatnio zmieniany przez slawekj : 04.12.2004 o godz. 18:16 |
| DVD Decrypter jak nagrć DVD ROM | max66 | DVD-Video | 6 | 01.01.2005 19:14 |
| problem z tmpg | fati | DVD-Video | 1 | 11.12.2004 22:24 |
| VCD na DVD można tak??? | gados82 | DVD-Video | 2 | 11.05.2004 17:05 |
| Chce kupić DVD playera - prosze pomóżcie mi wybrać | RNT-Robo | Napędy optyczne DVD | 12 | 07.05.2004 15:17 |
| Jak skopiowac dvd nagrana DVD X Copy XPress | zorba | DVD-Video | 10 | 29.07.2003 16:02 |
