Stary 11.09.2023, 17:33   #886
jadburner
Avatar użytkownika jadburner
Data rejestracji: 07.03.2017
Napisany przez 666mk6 Podgląd Wiadomości
Thank you for a reply.
But I have a problem.
I tried to cross-flash with DVR Tool v1.02, but it display this drive is not supported.
Do I have to be newer than this version?
PM sent.
jadburner jest offline
Stary 13.09.2023, 06:11   #887
jadburner
Welcome to the forums, 666mk6! Yes, the BDR-212DBK can be crossflashed to a BDR-S12UHT.
I need to clarify my comment: the BDR-212DBK can be crossflashed into a BDR-S12UHT as long as the firmware on the BDR-212DBK is dated earlier than December 2022. So the firmware would have to be version 1.02 or earlier.
Stary 13.09.2023, 17:06   #888
666mk6
Data rejestracji: 10.09.2023
666mk6 w tym momencie nie ma Reputacji dodatnich ani ujemnych <0  pkt>
Thanks for the heads up.
The obstacle before me now is that I do not have the BDR-S12UHT kernel on hand.
Is there a way to obtain it?
666mk6 jest offline
Stary 13.09.2023, 20:28   #889
jadburner
PM sent.
Stary 14.09.2023, 15:24   #890
666mk6
Thanks to jadburner, I was able to crossflush.
Thank you so much.
666mk6 jest offline
Stary 14.09.2023, 17:34   #891
lala64
Data rejestracji: 14.09.2023
lala64 w tym momencie nie ma Reputacji dodatnich ani ujemnych <0  pkt>
Hi
Is it possible to crossflash BDR-S09 drive to get UHD capabilities ?
DVR Tool only shows infos. Not possible to flash or dump
Thanks in advance
lala64 jest offline
Stary 14.09.2023, 20:07   #892
jadburner
Napisany przez lala64 Podgląd Wiadomości
Hi
Thanks in advance
Welcome to the forums, lala64! Which firmware version is currently on your BDR-S09?
Stary 14.09.2023, 20:19   #893
lala64
V. 1.54 (2020-07-21)
Did not put last version 1.55
lala64 jest offline
Stary 14.09.2023, 21:02   #894
jadburner
Thank you. PM sent.
Stary 14.09.2023, 21:39   #895
Oinker
Data rejestracji: 08.11.2022
Oinker w tym momencie nie ma Reputacji dodatnich ani ujemnych <0  pkt>
IIRC 1.03 is dated earlier than December 2022? At least the files in the updater exe are dated October 2022? Does 1.03 contain the downgrade/crossflash protection already? Or was it implemented first in 1.04?
Oinker jest offline
Stary 14.09.2023, 21:45   #896
jadburner
Napisany przez Oinker Podgląd Wiadomości
On Pioneer's web site, firmware 1.03 for the BDR-212DBK was updated December 21, 2022. So it is only firmware versions 1.02 and earlier that can be crossflashed.
Stary 14.09.2023, 21:55   #897
Oinker
Exclamation
Thx !
Oinker jest offline
Stary 14.09.2023, 22:08   #898
lala64
Thank you. PM sent.
Merci pour votre aide.
Voici mes infos
https://imgur.com/WGveshz
lala64 jest offline
Stary 14.09.2023, 22:15   #899
jadburner
Voici mes infos
PM sent.
Stary 14.09.2023, 23:01   #900
lala64
Thank you very much
Crossflashing went well and I'm now able to play my UHD discs
lala64 jest offline
dvrtool, pioneer
Pioneer BD Drive Utility czary2mary Programy do nagrywania, testowania, diagnostyki 16 05.02.2022 08:55
Linkownia\ firmware do CD\DVD\BluRay czary2mary Flashowanie/Firmware/Podkręcanie napędów optycznych 2 24.08.2019 18:09
[Komentarze] Flash Utility for LiteOn-made Drives i biblioteka biosów w wersji BIN -Sid-The-Rat=> Flashowanie/Firmware/Podkręcanie napędów optycznych 209 10.02.2006 15:01
Flash Utility for LiteOn-made Drives i biblioteka biosów w wersji BIN SoBal Flashowanie/Firmware/Podkręcanie napędów optycznych 0 28.09.2003 22:37
Wszystkie czasy w strefie CET. Aktualna godzina: 13:29.
