if there is a chance i can try it :-) i have 209D :-)
Ilość załączników: 11
Thanks to @blackened2687, I've had the opportunity to test his latest tool BDRFlash. The tool is currently at a v0.99 beta level, so it should be generally available real soon now. :)
One of the very useful features of the tool is the ability to crossflash between drives with similar attributes. As an example, here's the process for crossflashing a BDR-209D into a BDR-S11JBK. This allows the drive to utilize BDXL media and take advantage of new MIDs and other features of newer firmware. Here's the device information for a BDR-209D before any crossflashing. Załącznik 189749 As you can see, the drive lacks support for BDXL media. To begin, we start BDRFlash and select the drive to crossflash: Załącznik 189750 The Select command menu includes options to flash firmware and put the drive in kernel mode: Załącznik 189751 Since we want to crossflash the drive, we choose the Flash firmware option. We then need to use the file browse option to select the kernel and firmware files we want to flash to the drive. Since you need to select both files, you can use Ctrl-click to select them both. Załącznik 189752 Załącznik 189754 Załącznik 189753 blackened2687 provides the firmware/kernel files in folders, in this case a folder named BDR-S11JBK_1.52_v1. Once you've selected the files to flash, click the START button. If the program's internal consistency checks are satisfied, you'll see the confirmation dialog. Załącznik 189755 Select Yes, and a series of messages will appear as the program flashes the files. Here's one example: Załącznik 189756 When the flashing is complete, you'll see a success message. Here's the device information for our crossflashed drive. You can see that the drive is now a BDR-S11 and has support for BDXLmedia. Załącznik 189757 As final proof that the process worked, here's plots showing creation of a BDXL test disc and a quality scan of it. Załącznik 189758 Załącznik 189759 The process is really quite easy, and the program contains numerous checks to ensure that the drive and files to crossflash are matched. Great job, @blackened2687! |
Or BDR-209EBK ?
Now I have 2 mechanically defective BDR-PR1EPDV drivers.
can i backup these drivers with dvrtool and overwrite them on BDC-207DBK? Thank you very much for your interest and help. |
Hallo u need to wait only two person who can share this is czary2mary and blackened2687 |
Pioneer DVR-111DBK OEM Bufallo fw.8.25
Ilość załączników: 3
Pioneer DVR-TD08TBM
Ilość załączników: 2
PIONEER DVD-RW DVR-212 (GBDP003101WL)
tak samo nie pamiętam kiedy kupiłem :( Załącznik 151211 Załącznik 151212 |
Pioneer BDC-TD03RS firmware dump
Co myślicie czy jest jakaś szansa żeby naprawić ten napęd ?
Blackened2687: linki usunięte, napisałem do PW. :> |
fakt ubity podczas flashowania
Acer oficjalnie nigdy nie wydał firmware w postaci instalatora do tego modelu.
Możesz zapytać się suportu czy nie dysponują firmware do tego modelu. https://www.acer.com/ac/pl/PL/content/support |
| Wszystkie czasy w strefie CET. Aktualna godzina: 02:11. |
