Skąd można pobrać najnowszą wersję z GUI? Mam problem z flashowaniem DVR-215D po USB. Może ten soft coś pomoże...
Thank you. :) A BDR-XD07T i want to crossflash to BDR-XD07TUHD. |
What drives are you trying to crossflash to/from? |
Hello,
i´m trying to crossflash my Pioneer Drive. All tries with DVRTool from Post 1 haven´t worked. I have extracted the Firmware Binarys (131 and 132) from the official Updater but no success to Flash them to the Drive. I´m looking for the introduced BDRFlash Tool, but couldn´t find it. Can someone help out? Awesome what you guys are doing here. Thanks in advance. |
Use Opti Drive Speed. The program is free. Opti Drive Speed.
Hello. Is there possibility to limit cd reading speed with DVRTool on DVR-XD10T?
Hello i have a BDR-212DBK drive and i would like to flash it to an 212UBK. Is it only possible with the BDRTool or is there a nother method?
Thanks to blackened2687 and jadburner my 208Ds are 208Ms now. :D
https://forum.cdrinfo.pl/attachments...208dto208m.png |
Oh, thanks jadburner! I usually checked this page for firmware updates:
https://pioneer.jp/device_e/product-...v00001r_e.html And there is only one for the 211EBK/UBK drives. I don't mind waiting, blackened2687 being busy is a positive thing here. :) Looking forward to the firmware archive. ;) |
With respect to the S11, you can find 1.53 firmware for the BDR-S11J-BK and BDR-S11J-X here. Some, but not all, official flashers from Pioneer include both a kernel and firmware, which you can extract from the unpacked EXE. However, some flashers include only the firmware. In that case you need to either extract the kernel from a drive you have, or use one from the extensive archive that blackened2687 is assembling. A really neat feature of the latest version of BDRFlash is that you can drag and drop an official flasher on top of the program and it will automatically extract the firmware and (if it exists) the kernel in the same directory as the flasher. Many thanks to blackened2687 for adding that feature. :spoko: Hopefully you'll hear from blackened2687 soon, but he is very busy lately. |
Btw, if there's a kernel required, is it enough to unpack the updater exe and use the two files that get extracted in the BINARY folder then? They are about the same size, just have different filenames, e.g. the 208M firmware 1.40 had files S8301000.140 (69 kb) and S8301001.140 (1833 kb), the 1.50 firmware has 131 (69 kb) and 132 (1836 kb), i.e. there is no additional encryption of any kind on the newer files? And is it correct that there is no 1.53 available for the S11 like there is for the 211M model (i.e. the EBK/UBK drives)? |
| Wszystkie czasy w strefie CET. Aktualna godzina: 11:08. |
