Isn't the 212V a supposedly modified 212D? Nice to turn that into a UHD supporting writer. :D
Ilość załączników: 7
The BDR-212V can be crossflashed to a BDR-212UHBK, BDR-S12UHT, or BDR-212ULBK (among others) to enable BDXL writing and UHD ripping with appropriate software. Below are writing and ripping results after a BDR-212V to BDR-212UHBK crossflash. Rips were performed using AnyDVD and MakeMKV on two differently sized UHD discs.
Załącznik 198440 Załącznik 198441 Załącznik 198442 Załącznik 198447 Załącznik 198448 Załącznik 198449 Załącznik 198450 |
Welcome to the forums, gohclsin! PM sent.
Saw your post regarding the BDRFlash. I would like to crossflash from a BDR-212EBK (manufactured in 2019) to a BDR-S12UHT. Would that be possible with BDRflash? If yes, how to get this tool and the firmwares? Thank you in advance for your help. Regards, Goh C L |
I'm a newbie here but I have 2 Pioneer drives (BDR-209DBK and BDR209EBK) manufactured in 2018 that I'd like to cross-flash to enable reading of BDXL and possibly rip my 4K BR with MakeMKV. Would that be possible with BDRflash? If yes, how to get this tool and the firmwares? Thank you in advance for your help. PS : I also have a I-Odata slim external drive (basically a Pioneer BDR-UD02 - platform RS8410 - in USB 3.0 I-Odata enclosure) that cannot be used with MakeMKV. Any idea why? |
Welcome to the forums, DaveRiscman. Although the BDR-TD05 is capable of writing to quad-layer discs, since it's a BDXL drive, it never received a firmware update from Pioneer to enable it. That's why it won't properly recognize your SONY-NQ1 media. Unfortunately, I'm not aware of alternate firmware for the drive that would enable QL support.
Does it see that it's BD XL, quite possible that it does not have writing strategy for this particular BD XL.
The Sony discs are model 10BNR4VAPS4 if that's of any importance. |
Does it recognizes it's XL BD ?
Hello. I have a Pioneer BDR-TD05 drive inside of a Logitec casing (LBD-PME6U3). Logitec offered firmware up to 1.02, which I installed over the stock 1.00.
It's able to read standard BluRay videos, but if I try to burn 128GB Quad-Layer SONY BDXL discs, it's incompatible (ImgBurn reports "Incompatible Medium Installed"). The unit has a external power as well as USB, so I thought external power would fix it, but it didn't. I believe this issue is because of the firmware. My firmware is dated 2014, while the discs were only beginning to be manufactured in 2018. I downloaded every Logitec and Pioneer firmware available on their respective websites and parsed the firmware microcode file headers to see if there is a model with the same "Hardware Version", but there wasn't any. I found a mysterious 2.02 firmware on Fujitsu's website for the BDR-TD0. Fujitsu is using their own firmware flasher rather than the signed Pioneer one, and it's reporting my device as incompatible, though the microcode file embed in the flasher is the same format. My firmware: Kod:
S8211000.102Kod:
S8211721.202 |
Good day, guys!
I have BDR-TD05AS that doesn't read any disc (CD, DVD, or BD). I think it can be because of firmware (now its version is 1.01), but i can't find a way to update it. Could you give me advice what to do? Thanks! |
| Wszystkie czasy w strefie CET. Aktualna godzina: 11:08. |
