Stary 03.10.2026, 19:48   #31
mattjackson
Data rejestracji: 29.09.2026
mattjackson zaczyna zdobywać reputację <1 - 49 pkt>
https://freemkv.org/docs/pioneer-firmware/
mattjackson jest offline   Odpowiedz cytując ten post
Stary 04.10.2026, 07:54   #32
froggi
Data rejestracji: 19.03.2026
froggi zaczyna zdobywać reputację <1 - 49 pkt>
A quick catch-up since my last update: trev.bot beta.84 is available. Recent releases have added these flashing options for matching drives:
  • BDR-212DBK 1.02/1.03 to BDR-S12U 1.02.
  • BDR-212EBK 1.05 to BDR-212U 1.05.
  • BDR-XS07 1.01/1.04 and BDR-XS07U 1.04 to BDR-XS07U 1.01.
  • BDR-X12 1.04 to BDR-X12U 1.04.
  • More BDR-XD07 1.06 variants, plus BDR-XD07U 1.06, to BDR-XD07U 1.04.
  • BDE-PR1JAME 1.01, BDR-209MIO 1.54 and more BDR-209M 1.54 variants to BDR-211M 1.53.
Firmware surveys have expanded too, including Epson PR1EPDV 1.10, BDR-X12U 1.04 and BDR-208M 1.51, alongside improved Epson EP3 and BDR-TD05 survey handling. Thanks to everyone sending reports and feedback.
If you're already using the app, update from within it. Run the free Check to see which options apply to your exact drive and firmware.
Full release notes:
For anyone who prefers following updates in a feed reader, there's an RSS feed:
Hey Matt, could you move updates about your flasher to its own thread so this one stays on topic? Thanks.
Ostatnio zmieniany przez misiozol : 14.10.2026 o godz. 10:47 Powód: Expanded recent release details and added the RSS feed.
froggi jest offline   Odpowiedz cytując ten post
Stary 05.10.2026, 23:08   #33
Coopervid
Avatar użytkownika Coopervid
Data rejestracji: 04.09.2024
Coopervid w tym momencie nie ma Reputacji dodatnich ani ujemnych <0  pkt>
Napisany przez Stingray Podgląd Wiadomości
Could you tell me why many people choose the Pioneer BDR-212U firmware (or similar) instead of the S12JX? Personally, I install the MAX S11/S12 firmware versions to use the Pioneer utility for enabling Silent Mode foremost. To be honest, I almost never need UHD, since I mostly burn discs
Yes. JX is just for audio purposes but the firmware is not supported by Mike to support Libredrive.
Coopervid jest offline   Odpowiedz cytując ten post
Stary 06.10.2026, 01:23   #34
Stingray
Data rejestracji: 12.02.2024
Stingray zaczyna zdobywać reputację <1 - 49 pkt>
Napisany przez froggi Podgląd Wiadomości
could you please create a portable version
Stingray jest offline   Odpowiedz cytując ten post
Stary 14.10.2026, 00:36   #35
Coopervid
Wyszła wersja 1.0: obsługa LG, wiele platform, jedna licencja na wszystkie Twoje napędy zamiast licencji na jedno flashowanie. Szczegóły w nowym wątku:. czary2mary, skyrider, dzięki za pomoc.
Version 1.0 is out: LG support, cross platform, one license for all your drives instead of a license per flash. Details in the new thread: . czary2mary, skyrider, thanks for your help.
So? LG drives haven't been an issue for years. Marty's flasher just works fine.
Stary 15.10.2026, 21:52   #36
froggi
Napisany przez Coopervid Podgląd Wiadomości
You're right. Marty's flasher has worked for LG drives for years, and I wasn't suggesting otherwise. LG support in 1.0 means trev.bot now handles supported LG drives through the same guided check and flash flow as Pioneer. If Marty's flasher already works well for you, there's no reason to switch.
Stary 21.10.2026, 07:37   #37
froggi
LG flashing is FREE right now - $0.00. No license required.
Flashowanie LG jest teraz BEZPŁATNE - 0,00 USD. Bez licencji.
trev.bot flash 1.0.11
Wersja 1.0.11 jest już dostępna dla Windows, macOS i Linuksa. Flashowanie obsługiwanych napędów LG jest obecnie bezpłatne w okresie wprowadzającym. Licencja LG + Pioneer kosztuje teraz 19,99 USD (cena regularna 29,99 USD), obejmuje własne obsługiwane napędy na maksymalnie 3 komputerach i nie wygasa.
Poniżej nagranie rzeczywistego flashowania LG na moim Macu, w normalnym tempie. Aplikacja prowadzi przez sprawdzenie napędu, potwierdzenie i flashowanie.
Pobierz aplikację | Jak to działa i film w pełnej jakości
English
Version 1.0.11 is now available for Windows, macOS and Linux. Flashing supported LG drives is currently free during the introductory period. The LG + Pioneer license is $19.99 introductory pricing (regular price $29.99), covers your own supported drives on up to 3 computers, and does not expire.
Here is a real LG flash on my Mac at normal speed, showing the guided check, confirm and flash flow.
Download | How it works and full-quality video
Flashing Pioneer drives with firmware 12/2022+-lg-mac-flash-forum.gif
Ostatnio zmieniany przez froggi : 21.10.2026 o godz. 07:43
Stary 26.10.2026, 18:23   #38
froggi
Polski
trev.bot flash 1.0.17 jest dostępny dla systemów Windows, macOS i Linux.
Aktualizacja dodaje obsługę kolejnych wersji firmware napędów Pioneer i LG, usprawnia ustawienia napędów i przyspiesza odczyt firmware napędów Pioneer przez obsługiwane adaptery.
Sprawdź napęd w aplikacji, aby zobaczyć opcje dostępne dla jego dokładnego modelu i wersji firmware.
Zmiana ustawień, takich jak PureRead w obsługujących je napędach Pioneer, nie wymaga licencji. Nadal obowiązuje cena promocyjna dla wersji 1: flashowanie napędów Pioneer kosztuje 19,99 USD za wszystkie Twoje urządzenia (nie jest to licencja na pojedynczy napęd), a flashowanie napędów LG kosztuje 0,00 USD.
Pobierz aplikację | Pełna lista zmian
English
trev.bot flash 1.0.17 is available for Windows, macOS and Linux.
This update adds support for more Pioneer and LG firmware versions, improves drive settings, and makes Pioneer firmware reads faster on supported adapters.
Check your drive in the app to see the options available for its exact model and firmware.
Changing settings such as PureRead on applicable Pioneer drives doesn't require a license. The version 1 intro rate is still active with Pioneer flashing at $19.99 for all of your devices (this isn't a per drive license) and LG flashing is $0.00.
Downloads | Full changelog
12/2022+, drives, firmware, flashing, pioneer
Wszystkie czasy w strefie CET. Aktualna godzina: 22:40.
