Stary 30.05.2017, 10:20   #571
DVRTool 1.0298j Beta
DVRTool v1.0 - firmware flashing utility for Pioneer DVR/BDR drives-2017-05-30_09-31-24.png
DVRTool v1.0 - firmware flashing utility for Pioneer DVR/BDR drives-2017-05-30_09-32-10.png
DVRTool v1.0 - firmware flashing utility for Pioneer DVR/BDR drives-2017-05-30_09-32-31.png
DVRTool v1.0 - firmware flashing utility for Pioneer DVR/BDR drives-2017-05-30_09-33-59.png
DVRTool v1.0 - firmware flashing utility for Pioneer DVR/BDR drives-2017-05-30_09-35-29.png
czary2mary jest offline
Stary 31.05.2017, 06:11   #572
jadburner
Avatar użytkownika jadburner
Data rejestracji: 07.03.2017
Napisany przez blackened2687 Podgląd Wiadomości
jadburner, thank you very much for the data dumps! Helped me a lot to figure out some drive settings.
A question: have you got any slim TEAC drive from DV-W28xxxx series? There is a rumor that some of these drives are rebadged Pioneer drives, but I don't have access to any of them to check it out.
blackened2687 - Just saw this. You're welcome for the data dumps. I still need to get you the dumps from my BDR-XS05T. Soon.
I'm pretty sure I have a couple hiding around here somewhere. I'll try to find them for you.
Good to hear from you.
jadburner jest offline
Stary 03.06.2017, 06:49   #573
DVRTool v1.0 - firmware flashing utility for Pioneer DVR/BDR drives-2017-05-18_16-37-31.png
DVRTool v1.0 - firmware flashing utility for Pioneer DVR/BDR drives-2017-05-18_17-15-08.png
DVRTool v1.0 - firmware flashing utility for Pioneer DVR/BDR drives-2017-05-19_11-46-52.png
Stary 03.06.2017, 14:50   #574
blackened2687
CDRinfoTeam
Data rejestracji: 19.04.2014
Lightbulb
jadburner, thank you!
To gather the necessary drive information more easily, I've made a small one-button program (called it Pioneer Data Dumper):
http://www60.zippyshare.com/v/Tt8wTvdO/file.html
The usage is simple as possible: enter the drive letter followed with a colon and click [Dump Data]. Resulting file is something that I need to properly add the drive support.
To everybody: If you will find some slim Pioneer BD drive from the list below, please dump its data using the Pioneer Data Dumper and send the file to czary2mary or to me. It will greatly help to add the most of existing Pioneer drives to the program.
Wszystkim: Je***347;li ktokolwiek znajdzie jaki***347; nap***281;d slim Pioneer BD z poni***380;szej listy, serdecznie prosz***281; o dump danych za pomoc***261; Pioneer Data Dumper i o wysy***322;ce plika do czary2mary lub do mnie. Bardzo to pomo***380;e mi w dodaniu wi***281;kszo***347;ci istniej***261;cych nap***281;dów Pioneer do programu.
List:
BDR-TD02 (BDR-TD02VA)
BDC-TD02 (BDC-TD02VA, BDC-TD02RS)
BDC-TS02 (BDC-TS02PB)
BDR-TS04 (BDR-TS04FAD, TEAC BD-W26SS-BM3)
BDC-US01 (BDC-US01VA, TEAC BD-C16SS-A90)
BDR-UD02 (BDR-UD02AS, BDR-UD02B, BDR-UD02FAN, BDR-UD02TBD, BDR-UD02VA, BDR-UD02VB)
BDC-UD02 (BDC-UD02AS, BDC-UD02TBD, BDC-UD02VA)
BDC-UD03 (BDC-UD03AS)
BDR-UD04 (Logitec LBD-PUD6U3L)
Ostatnio zmieniany przez blackened2687 : 17.12.2017 o godz. 17:59
blackened2687 jest offline
Stary 03.06.2017, 22:58   #575
jadburner
Found one of them.
Teac DV-W28S-V42
From DVRTool:
Drive Information:
Model Name : TEAC DV-W28S-VS
Firmware Rev : G.V0
Extra Info :
Serial Number : XXXXXXXXXX****
Buffer Size : 2000 kiB
Additional Drive Information:
Label Code : ****************
Hardware Rev : STE 0282
Kernel Type : TEAC
Firmware Type : TEAC
Kernel Version : 0001
Drive is in normal mode.
Firmware flashing support : YES
Firmware dumping support : YES
Drive Capabilities:
CD-ROM : R BD-ROM : -
CD-R : R/W BD-R : -
CD-RW : R/W BD-R XL : -
DVD-ROM : R BD-RE : -
DVD-R : R/W BD-RE XL : -
DVD-R DL : R/W HD DVD-ROM : -
DVD-RW : R/W HD DVD-R : -
DVD+R : R/W HD DVD-R DL : -
DVD+R DL : R/W HD DVD-RW : -
DVD+RW : R/W LabelFlash : NO
DVD-RAM : R/W LightScribe : YES
Drive Region Settings:
RPC Scheme : RPC-2
Current Region : 0
Changes Left : 5 (available to user)
Resets Left : 4 (available only to vendor)
Region State : Region is not set
Stary 03.06.2017, 23:29   #576
blackened2687
CDRinfoTeam
Wow!!! And even the LightScribe version!
So, it's true: DV-W28S-Vxx series drives does appear to be rebadged DVR-TD09 drives, and that is very good!
Thank you very much! Would be great to find more drives from these series!
Stary 04.06.2017, 00:57   #577
jadburner
Here you go: DV-W28SLC
DVRTool v1.0 - firmware flashing utility for Pioneer DVR/BDR drives-device-info.png
Stary 04.06.2017, 07:17   #578
blackened2687
CDRinfoTeam
jadburner, thank you very much for more dumps! Could you please also dump additional data with Pioneer Data Dumper from DV-W28SLC?
And is it possible to look at the full name of the drive on the label? With all the hyphens and additional numbers outside the square frame. Of course, if the drive is not installed in the laptop or if it's not too difficult to remove. If it's installed in the laptop, then i need the full laptop model code.
Drive full model code should be like DV-W28SL-C-1D2. DV-W28SL is in the square, and C-1D2 is outside on one line with main model name.
Thanks in advance!
I'm amazed to find that DV-W28SLC is also a Pioneer drive - 0072 is the hardware code of DVR-K17 drives - but DVR-K17 is a tray loading drive! I assume, that the slot loader itself is made by different manufacturer - Pioneer made only the board, firmware and optical pickup. Interesting drive - definitely worth to have!
Ostatnio zmieniany przez blackened2687 : 04.06.2017 o godz. 07:21
Stary 04.06.2017, 20:35   #579
jadburner
Sent via PM.
Stary 04.06.2017, 20:38   #580
jadburner
Sure, here are the labels from the two drives:
DVRTool v1.0 - firmware flashing utility for Pioneer DVR/BDR drives-teac-dv-w28s-v42-label.jpg
DVRTool v1.0 - firmware flashing utility for Pioneer DVR/BDR drives-teac-dv-w28slc-label.jpg
Stary 04.06.2017, 21:00   #581
blackened2687
CDRinfoTeam
Wow! Thank you very much for the photos and the dump!
More info: I've researched a bit about slim TEAC drives and can now suggest which series used the Pioneer hardware:
DV-W28ECxx - DVR-K17
DV-W28SLCxx - DVR-K17 (with slot loader not made by Pioneer)
DV-W28E-Rxx - DVR-KD08
DV-W28S-Rxx - DVR-TD08
DV-W28S-Vxx - DVR-TD09
DV-W28U-Vxx - DVR-TD09 (external drive)
Maybe there are more rebadged Pioneer drives, we have yet to figure it out.
jadburner, have you ever heard of Toshiba Portable SuperMulti Drive PA3834U? It seems that this drive is also a rebadged Pioneer, but I've failed to find any firmware for it to check out.
Stary 04.06.2017, 21:05   #582
blackened2687
CDRinfoTeam
Sent via PM.
Hmm... I haven't received the message.
Stary 04.06.2017, 21:22   #583
jadburner
Apparently the DV-W28S-WTN is NOT a Pioneer drive:
Stary 04.06.2017, 21:23   #584
jadburner
Sorry, I'll re-send.
Stary 04.06.2017, 21:32   #585
jadburner
Yes, I **think** I have one hiding here somewhere. I'll add it to my list of drives to look for.
dvrtool, pioneer
Pioneer BD Drive Utility czary2mary Programy do nagrywania, testowania, diagnostyki 16 05.02.2022 09:55
Linkownia\ firmware do CD\DVD\BluRay czary2mary Flashowanie/Firmware/Podkręcanie napędów optycznych 2 24.08.2019 18:09
[Komentarze] Flash Utility for LiteOn-made Drives i biblioteka biosów w wersji BIN -Sid-The-Rat=> Flashowanie/Firmware/Podkręcanie napędów optycznych 209 10.02.2006 16:01
Flash Utility for LiteOn-made Drives i biblioteka biosów w wersji BIN SoBal Flashowanie/Firmware/Podkręcanie napędów optycznych 0 28.09.2003 22:37
Wszystkie czasy w strefie CET. Aktualna godzina: 07:19.
