Stary 20.07.2017, 10:33   #631
Pioneer DVR-104MB:
Efficient? Where do you have such OEM Compaq?
http://www.cdrinfo.pl/hardware/20801...ioneer-DVR-A04
Can you ask for pictures like looks and factory labels?
Is it possible to factory update to newer firmware?
I have DVR-A04 and DVR-104 \ 2
Pioneer DVR-A04
Pioneer DVR-104\2
czary2mary jest offline
Stary 21.07.2017, 03:36   #632
jadburner
Avatar użytkownika jadburner
Data rejestracji: 07.03.2017
I got the drive off of eBay a few years ago. Apparently it came from a Compaq desktop. I have not tried any burns yet, since I was hoping to upgrade the firmware first. I tried flashing with Pioneer firmware, bit it would not work.
Here's some photos of the drive:
DVRTool v1.0 - firmware flashing utility for Pioneer DVR/BDR drives-front.jpg
DVRTool v1.0 - firmware flashing utility for Pioneer DVR/BDR drives-back.jpg
DVRTool v1.0 - firmware flashing utility for Pioneer DVR/BDR drives-bottom.jpg
DVRTool v1.0 - firmware flashing utility for Pioneer DVR/BDR drives-label.jpg
jadburner jest offline
Stary 21.07.2017, 07:25   #633
blackened2687
CDRinfoTeam
Data rejestracji: 19.04.2014
jadburner, thank you very much for the screenshots and drive photos!
If you will decide to crossflash the drive, I will advice not to do it with DVRTool, until I'll test it personally on this drive. We had troubles with DVR-105 crossflashing twice - both times something went wrong and DVRTool hung after sendng the first part of kernel file (apparently waiting the response from the device) - as a result, two drives now require to flash the system controller using an external hardware (which I don't have). Since DVR-104 drives are rare, i will advice not to use DVRTool for their crossflashing, until everything will be tested.
blackened2687 jest offline
Stary 21.07.2017, 08:09   #634
@jadburner
Thank you very much for the photos. I have never met a version with a black front panel.
@blackened2687
Do you have any kernel for DVR-A04 \ 104 ? I have never met nor seen anywhere?
Stary 21.07.2017, 19:28   #635
jadburner
Napisany przez blackened2687 Podgląd Wiadomości
blackened2687, thank you for the warning. I'm in no rush to kill the drive, so I will wait until there's a safe way to update or crossflash the drive.
Stary 21.07.2017, 19:42   #636
jadburner
The only DVR-104M drives I've seen on eBay were always DVR-104MB, so I assume all of the Compaq versions were black.
Stary 22.07.2017, 09:53   #637
Got something else from the first Pioneer models?
I recently watched Pioneer DVR-S201 but it was so damaged and damaged that I could not fix it.
DVRTool v1.0 - firmware flashing utility for Pioneer DVR/BDR drives-2017-07-22_09-51-56.png
Stary 22.07.2017, 20:26   #638
jadburner
Załącznik 98643
I have a DVR-S201 also. It's in good condition, but I no longer have a SCSI connection to test it.
Stary 22.07.2017, 22:38   #639
jadburner
Pioneer DVR-X152 external drive:
DVRTool v1.0 - firmware flashing utility for Pioneer DVR/BDR drives-device-info.png
Stary 22.07.2017, 23:39   #640
We have practically no Pioneer DVR-S101 \ S201. I know only one place in Poland that used to have and used DVR-S201 ....
Too bad you no longer have a SCSI or SCSI adapter working ....
Please put this unique model with a picture in our museum.
Muzeum\Mauzoleum DVD
Stary 23.07.2017, 06:56   #641
DVRTool 1.0298j Beta
DVRTool v1.0 - firmware flashing utility for Pioneer DVR/BDR drives-2017-07-22_13-19-03.png
DVRTool v1.0 - firmware flashing utility for Pioneer DVR/BDR drives-2017-07-22_13-19-51.png
DVRTool v1.0 - firmware flashing utility for Pioneer DVR/BDR drives-2017-07-22_13-20-49.png
Stary 24.07.2017, 01:23   #642
jadburner
Sure, I'll ad some photos. I was wrong about it being in good condition, it's actually in brand new, unused condition.
I'll see if I can do about getting it hooked up...
Stary 24.07.2017, 07:05   #643
Congratulations on this new unique model and thank you very much for placing in our Museum.
I only have the oldest DVR-103 \ A03.
Here is a sample test @ Blackened2687
[Muzeum] Pioneer DVR-A03 - 2001r
Stary 27.07.2017, 07:43   #644
jadburner
Pioneer DVD-116LJ:
Stary 28.07.2017, 07:05   #645
jadburner
Pioneer A09XLB1:
dvrtool, pioneer
Pioneer BD Drive Utility czary2mary Programy do nagrywania, testowania, diagnostyki 16 05.02.2022 09:55
Linkownia\ firmware do CD\DVD\BluRay czary2mary Flashowanie/Firmware/Podkręcanie napędów optycznych 2 24.08.2019 18:09
[Komentarze] Flash Utility for LiteOn-made Drives i biblioteka biosów w wersji BIN -Sid-The-Rat=> Flashowanie/Firmware/Podkręcanie napędów optycznych 209 10.02.2006 16:01
Flash Utility for LiteOn-made Drives i biblioteka biosów w wersji BIN SoBal Flashowanie/Firmware/Podkręcanie napędów optycznych 0 28.09.2003 22:37
Wszystkie czasy w strefie CET. Aktualna godzina: 01:04.
