VERBATIM DVD+R 16x 4.7GB
Jak już ktoś napisał ( kataryniarz ) nareszcie trafiły mi się Verbatimy YUDEN000 DVD+R 16x. Na początek blok MID: DVDInfo V3.51 (DVDInfo Pro)
Media Information Region information N/A not a DVD-VIDEO Media code/Manufacturer ID YUDEN000T03 Media Product Revision Number 00h Format Capacity Blank Disc Free Blocks 405405696 Free Capacity 4.38GB(4.70GB) Book Type DVD+R Media Type DVD+R Manufacturer Rated Speed Unknown Available Write Descriptor CLV 16.0x 22160KBps Available Write Descriptor CLV 12.0x 16620KBps Available Write Descriptor CLV 8.0x 11080KBps Available Write Descriptor CLV 6.0x 8310KBps Available Write Descriptor CLV 4.0x 5540KBps Data area starting sector 30000h Linear Density 0.267um/bit Track Density 0.74um/track Number of Layers 1 Complete Media Code 00000000 01 02 00 00 A1 0F 02 00 00 03 00 00 00 26 05 3F .............&.? 00000010 00 00 00 00 00 00 07 59 55 44 45 4E 30 30 30 54 .......YUDEN000T 00000020 30 33 00 38 23 54 37 0B 02 5A 71 02 80 6F 0F 0F 03.8#T7..Zq..o.. 00000030 0A 09 02 02 00 19 1B 0C 0C 0C 0D 00 00 00 00 00 ................ A teraz FE/TE ( Focus i Track ERROR Test ) Warunki optymalne: //brak drgań ( muzyka Vol.0 i papierosek w ręku z dala od kompa. ;)): Na temat tego testu po Angielsku ( nie skomplikowany poziom ) z manuala PLEXTools Pro V2.27: Q-Check FE/TE Test: (only available for PlexWriter Premium / PX-712A / PX-716A / PX-760A) Write test for blank CD-R/RW and DVD R/RW media (in simulation mode). This test will measure the mechanical characteristics of the media. FE (Focus Errors): indicates how well the pickup can focus the laser beam on the disc surface. TE (Tracking Errors): indicates how well the pickup can follow the spiral track of the disc. If these numbers are too high, there is a chance that a write error will happen. In this case the recording should be performed at a lower speed. This test will be performed at the highest recording speed in simulation mode. At the end of the test, the testresult will indicate if this media can be written at the highest speed with good quality. |
Ilość załączników: 5
ostatnia szt. z cake 25szt.
palona 6x na Px 760v1.06 Załącznik 39728 Załącznik 39729 Załącznik 39730 Załącznik 39731 Załącznik 39732 |
Na liteonach powinno sie skanowac 4x bo wtedy wynik jest najdokladniejszy
Ilość załączników: 4
Kolejna płytka wypalona i kolejny skan, tym razem oprócz CDSpeed'a również za pomocą DVD-Info Pro. Skany wykonane prędkością x4 oraz x8. Widać, że nie ma zbyt dużej różnicy pomiędzy prędkościami skanowania. Zastanawia mnie jednak fakt, dlaczego DVD-Info Pro zaniża wartości PI? A może to CDSpeed je zawyża? Czy ktoś wie czego to może być przyczyna?
Aha, płytki palone na LiteOnie prędkością znamionową, czyli x16 ;) |
Ilość załączników: 3
verby palone 8x M in Taiwan ..... i zmian biosu nic nie wskrala jak trefna partia to ....
Załącznik 39411 Załącznik 39412 Załącznik 39413 |
verby od MCC, jak i inne no***347;niki pal***281; 8x :taktak:
s***261; czytane przez stacjonark***281; i to mnie cieszy ;) |
jaką szybkością polecacie wypalać te Verby?
Ja wczoraj wypaliłem 12X to wyszło gorzej niż 18X. Wprost 12X i na dvd-romie LiteOna czerwono podczas testów. pzdr |
Czary;) Jeżeli nie zrobiłeś wcześniej testu TE/FE, to już niczego się nie dowiesz;) :D |
Nie wiem czy ta plyta powinna trafic do tego dzialu ale w koncu to jest Verbatim tylko ze LightScribe palony 8x na liteon 18a1h z OHP, troche mnie dziwi ten przeskok na srodku wykresu ciekawy jestem czym byl spowodowany :hmm:
Zale***380;nie od wielko***347;ci tych b***322;***281;d***243;w dobieramy pr***281;dko***347;***263; zapisu. Oczywi***347;cie jak poradzi sobie nap***281;d z b***322;***281;dami TE/FE zapisywanej p***322;ytki zale***380;y od OPC nap***281;du. Bezpieczna pr***281;dko***347;***263; zapisu przy obecnej jako***347;ci no***347;nik***243;w to max 8x. :) |
Wiem, że w tym przypadku maksymalna prędkość to ok x12 - nie musisz mi mówić, zaczyna się od ok x2 i rośnie w miarę zbliżania sie lasera do brzegu płyty. Nie rozumiem co masz na myśli, że prędkość zapisu x16 nadaje się tylko do testów :ysz: Kolejna sprawa, to fakt, że przy testowaniu prędkością x4 wyniki mam podobne, ale jak zrobię test, to zamieszczę :taktak:
A co do jittera, to faktycznie - jest on wysoki. Jak można go zmniejszyć? Co wpływa na jego wynik? |
I nie ma co się chwalić. 16x to zapis wyłącznie dla testów. :spoko: Testy na LiteOn'ie robimy prędkością 4x. A bardzo dobrze.... :czytaj: i porównaj Jitter. http://forum.cdrinfo.pl/showpost.php...&postcount=421 :) |
Płytki palone prędkością x16. Te same płytki nagrywane w napędzie LG GMA-4082N (w laptopie) prędkością x8 mają podobne rezultaty. Jednak palone poniżej tej prędkości już są nie do odczytania.
@punisher Chwalę się, bo to jak na razie najlepsze rezultaty nagrywanych płyt na moim napędzie. Co ciekawe takie wyniki otrzymałem włączając opcję HyperTuning, którą obsługuje mój Litek. Wygląda na to, że on sam jakoś koryguje strategię zapisu na podstawie wypalonych płyt danego producenta. Nie mniej cieszą mnie rezultaty. Jak na razie tylko i wyłącznie - Verbatim :spoko: |
Wszystko pięknie, ale jeszcze mógłbyś napisać z jaką prędkością paliłeś? i Chyba nie ma czym sie chwalić :P
| Wszystkie czasy w strefie CET. Aktualna godzina: 03:01. |
